Which Cisco Autonomous APs work as bridges?
I am wondering which Cisco autonomous APs can operate as wireless bridges (station role root and non-root)?  Particularly interested in 1602E and 2602E APs.  The documentation I've looked at so far doesn't specifically state that it is/is not supported.
Everyone's tags (3)
2 ACCEPTED SOLUTIONS
VIP Purple
Re: Which Cisco Autonomous APs work as bridges?
Yes, these model you can configure as Root/Non-Root as long as you have an autonomous image loaded. Most of the time feature is depend on the software code.
Release notes available at below URL for details of the supported/unsupported features of each software version.
http://www.cisco.com/en/US/products/ps12555/prod_release_notes_list.html
Here is one basic config example of Root/Non-Root using different AP model, but it may help you to get basic config done for these AP model as well.
http://mrncciew.com/2013/11/09/wireless-bridge-with-eap-fast/
Rasika
**** Pls rate all useful responses ****
Yes these AP's 1600 and 2600 may definetly.. work as root and non oot bridge..
VIP Purple
Rasika
255
