While copy IOS image by TFTP CISCO aironet 1200
Hi All,
Today i erase my Cisco aironet FLASH.
Now when i trying to copy new image to AP it give me permisstion denied error.
I tried everythig that was discussed in same case.
1 i set my system ip address by
ap: set IP_ADDR 192.168.1.1
ap: set NETMASK 255.255.255.0
ap: set DEFAULT_ROUTER 192.168.1.2------this is TFTP Server ip
After that i execute
tftp_init
Now image location on my PC is as c:/TFTP-ROOT/c1200-k9w7-tar.123-8.JEC3.tar
Can anyone help me .
What command i have to enter to copy this image to CISCO AP.
I tried to copy by
copy tftp://192.168.1.2/c:/TFTP-ROOT/c1200-k9w7-tar.123-8.JEC3.tar flash:
It give me error
access denied
ot permission denied ...............it there is any problem in permission of flash directory if that is case how can i change the permission of Flash
Also When i tried to ping 192.168.1.1(AP ip) with My TFTP ip 192.168.1.2...... iam not getting any response.(i am using straight cable)
Please send me a proper procedure
1 ACCEPTED SOLUTION
Re: While copy IOS image by TFTP CISCO aironet 1200
The commands for a rommon recovery on an AP are a bit different than what you do on a switch or a router.  Take a look at the below link.
https://supportforums.cisco.com/docs/DOC-14636
Basically, instead of calling the tftp you call tar -xtract
tar -xtract tftp://192.168.1.2/c1200-k9w7-tar.123-8.JEC3.tar flash:
You'll need to be watching to hit the space bar when the ---MORE--- comes up, otherwise it will time out.
you shoulnd't have to call the full path, if your TFTP server points at your TFTP-ROOT directory.  If you just point it at c: then you would need to do the full call.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
1 REPLY
Steve
3603
