06-06-2007 06:29 AM - edited 07-03-2021 02:10 PM
Here's the config, I can't see the ssid from my laptop but I can see others.
hostname test
boot-start-marker
boot system flash:c181x-advipservicesk9-mz.124-9.T.bin
boot-end-marker
logging buffered 128000 debugging
logging rate-limit all 500
clock timezone EST -5
clock summer-time EDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
clock calendar-valid
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause rootguard
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
no ip source-route
ip icmp rate-limit unreachable 5
ip icmp rate-limit unreachable DF 5
ip dhcp pool 1800-wireless
network 10.205.2.0 255.255.255.0
no ip bootp server
no ip domain lookup
ip domain name retail.afterhours.com
ip name-server 10.200.1.4
ip name-server 10.200.1.9
ip multicast-routing
ip ssh version 2
bridge irb
interface FastEthernet0
ip address removed
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
duplex auto
speed auto
no cdp enable
interface FastEthernet1
no ip address
load-interval 30
shutdown
duplex auto
speed auto
no cdp enable
interface Dot11Radio0
no ip address
ssid space
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
no cdp enable
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-dense-mode
ip policy route-map 1
load-interval 30
bridge-group 1
interface BVI1
ip address 10.205.2.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.200.2.1
ip route 0.0.0.0 0.0.0.0 Dialer1 250
no ip http server
no ip http secure-server
ip pim autorp listener
logging trap debugging
route-map 1 permit 10
set ip df 0
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner exec
06-06-2007 07:03 AM
nevermind, I found the answer. You have to setup the guest mode to connect while browsing. Also, windows doesn't even show you connected if you list it as an infrustructure ID in XP. Additionally, you have to set it up as automatic with the right parameters if you want it to connect. Otherwise, it won't and you won't see it either.
