06-03-2014 03:49 AM - edited 07-05-2021 12:56 AM
Dears,
I faced strange behavior i have two WLC one primary and the other one secondary.
some AP join to secondary WLC for short period (2 min or less) and returned to primary, while they are configured to primary WLC.
Two WLC image version: 7.4.121.0
Wait your replies plz.
06-03-2014 04:02 AM
From which controller AP will join it is depends on our configuration on each WLC: The AP can be configured to recognize its primary and secondary controller name.
Wireless > Access Points > All APs > Select AP > High Availability Configuration
Change the primary wlc ip and name to 2nd wlc ip address/name , then check again.
More info about failover:
http://rscciew.wordpress.com/2014/01/22/ap-failover/
Dont forget to rate helpful posts
06-03-2014 04:06 AM
Thanks for your reply,
Already i configured HA Configuration on all AP, and working well.
but i mean there are some AP leave primary controller and join Secondary for 2 min approximately and returned again to Primary WLC. While these AP previously configured with HA Configuration.
Plz give me your feedback.
06-03-2014 04:08 AM
means AP are loosing connection with primary wlc thats the only reson to join 2nd WLC.
06-03-2014 04:38 AM
Thanks for your support.
Please can you clarify why APs loosing connection with Primary WLC however it's up and joined on it more than 300 AP in different sites.
For Clarification AP join on Secondary WLC and fallback to Primary within 2 minutes approximately.
Wait your feedback please,
06-03-2014 04:32 AM
Thanks for your support,
Please Can you clarify why AP Loosing the connection with primary WLC however its up and joined on it more than 300 AP from different sites.
and for clarification after AP joined the secondary WLC fallback to Primary with in 2 minutes.
Wait your feedback Please.
06-03-2014 04:39 AM
Can you paste logs from wlc and AP console. Then we can find out the root cause.
06-03-2014 04:56 AM
please find Logs from Secondary WLC. and i can't get Access point logs cause i Remote site.
465 Tue Jun 3 13:20:36 2014 AP '90068-02', MAC: 34:a8:4e:bb:08:90 disassociated previously due to Link Failure. Uptime: 0 days, 18 h 46 m 25 s . Reason: Capwap WTP Event request.
466 Tue Jun 3 13:20:36 2014 AP on the 802.11a radio with Base Radio MAC 34:a8:4e:bb:08:90 (90068-02) is unable to associate. The regulatory domain configured on it '-E' does not match the controller's regulatory domain: -C
493 Tue Jun 3 13:16:59 2014 AP '90068-02', MAC: 34:a8:4e:bb:08:90 disassociated previously due to Link Failure. Uptime: 0 days, 18 h 42 m 55 s . Reason: Capwap WTP Event request.
494 Tue Jun 3 13:16:59 2014 AP on the 802.11a radio with Base Radio MAC 34:a8:4e:bb:08:90 (90068-02) is unable to associate. The regulatory domain configured on it '-E' does not match the controller's regulatory domain: -C
59 Tue Jun 3 13:20:42 2014 AP '90068-01', MAC: 34:a8:4e:bb:06:30 disassociated previously due to Link Failure. Uptime: 0 days, 18 h 47 m 17 s . Reason: Capwap WTP Event request.
460 Tue Jun 3 13:20:42 2014 AP on the 802.11a radio with Base Radio MAC 34:a8:4e:bb:06:30 (90068-01) is unable to associate. The regulatory domain configured on it '-E' does not match the controller's regulatory domain: -C
0 Tue Jun 3 14:51:09 2014 Coverage hole pre alarm for client[1] 94:01:c2:82:26:27 on 802.11b/g interface of AP 54:78:1a:88:2c:c0 (90002-01). Hist: 0 0 1 1 4 8 26 30 22 24 12 21 9 7 3 7 2 2 1 1 0 0 0 0 0 0 0 0 0 0 0
1 Tue Jun 3 14:51:09 2014 Coverage hole pre alarm for client[1] 88:32:9b:5f:e7:91 on 802.11b/g interface of AP 54:78:1a:88:2c:c0 (90002-01). Hist: 1 4 7 15 4 9 4 4 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
2 Tue Jun 3 14:51:09 2014 Coverage hole pre alarm for client[1] cc:3a:61:69:d9:4c on 802.11b/g interface of AP 54:78:1a:88:2c:c0 (90002-01). Hist: 0 0 0 0 0 2 13 16 19 13 5 6 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
3 Tue Jun 3 14:51:09 2014 Coverage hole pre alarm for client[1] bc:44:86:09:f1:ec on 802.11b/g interface of AP 54:78:1a:88:2c:c0 (90002-01). Hist: 0 0 0 3 21 24 13 6 2 1 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 1 0 2 3 0 0
Wait your feedback plz.
06-03-2014 05:06 AM
06-03-2014 09:18 AM
How to change country on WLC:
By CLI
Before you can change the country code of a WLC, you must disable the 802.11a and 802.11b network :
config 802.11a disable network
config 802.11b disable network
Now you can change the country code of the controller. In this case we change it from CN to FR (France)
config country FR
then enable again the both networks
config 802.11a enable network
config 802.11b enable network
By GUI:
First disable both network 802.11a and 802.11b
Follow these steps to disable the 802.11a and 802.11b/g networks as follows:
Choose Wireless> 802.11a/n > Network.
Unselect the 802.11a Network Status check box.
Click Apply to commit your changes.
Choose Wireless > 802.11b/g/n > Network.
Unselect the 802.11b/g Network Status check box.
Change country code on WLC now:
Choose Wireless > Country
06-03-2014 05:10 AM
Can you check these:
Tue Jun 3 13:16:59 2014 AP on the 802.11a radio with Base Radio MAC 34:a8:4e:bb:08:90 (90068-02) is unable to associate. The regulatory domain configured on it '-E' does not match the controller's regulatory domain: -C.
Both AP and WLC must match the reulatery domain.
Paste output from AP: sh version
Paste from WLC: sh sysinfo
06-03-2014 06:17 AM
Plz find attached files
Sh ver --> AP
sh sysinfo --> 2 WLC
For clarification we have this log also
If this mean the AP loosing connectivity due to network/routing issue ?
or as example AP send CAPWAP message and didn't receive response from Primary WLC so join on secondary and once get the response from primary returned and join to it.
Wait your feedback plz,
06-03-2014 09:15 AM
As per your logs:
1st wlc have country code france.
(WiSM-slot2-1) >show sysinfo
System Name...................................... RMS-WLC1
Configured Country............................... FR - France
2nd wlc have country code China.
System Name...................................... UTO-WLC1
Configured Country............................... CN - China
and your AP only can be used for europe domain:
AIR-CAP1602I-E-K9
So it can work with china domain. You must change the country code on your UTO-WLC1.
06-03-2014 09:20 AM
OK i agree with you about country coded. but this not related to AP joined on Secondary and Quickly fallback to primary again.
wait your feedback.
06-03-2014 10:51 AM
I am not sure about this. But give a try and change country first and test it again. It may helps and then we can go ahead with troubleshooting.
