01-13-2014 08:38 AM - edited 07-04-2021 11:57 PM
Can you please advise which cisco solution for wifi is better for bigger office.
I am looking to implement on two floors.
01-13-2014 09:02 AM
HI Mohammad,
Just in short:
for what purpose you want to use ...like for guest or employees or?
OInly for production area or ?
You can use Controller based solution : You need to buy a controller(2504 or 5508) and Cisco AP (2600 or as per ur requirment)
1. Plan ur requirments
2. Make a site survey.(Survey will show that how many AP u need ...)
3. Then deploy.
01-13-2014 10:01 AM
Hi Sandeep,
We have already got two wifi routers serving for employees and guest but connection drops and sometimes out of range. I want to replace it with better and reliable system.
01-13-2014 10:48 AM
Do I need to buy WLC ? Is it a better way to implement wireless network? Would AP serve production and guest network simultaneously?
01-13-2014 10:53 AM
If you have the budget... Then yes, it's the best way to implement wireless these days. You will be able to manage all AP's from the WLC and not have to manage each AP. Roaming and many of the newer features are also available when implementing a WLC.
01-13-2014 11:31 AM
HI Mohammed,
If you have enough budget then it is the best solution.
Benifits of WLC:
....any many more.
01-13-2014 12:21 PM
So am I ok to assume One AP can support Production and Guest both?
How and where I should get the quote from for WLC and two or three APs?
Any recommendation?
01-13-2014 12:43 PM
Because we don't know what country you are in, we do not know who the authorized Cisco resellers in that country are. So instead, you'll have to search and choose for yourself. Go here to search: http://tools.cisco.com/WWChannels/LOCATR/openBasicSearch.do
You won't know how many APs you will need unless you are able to get a wireless site survey done. Do that, and you'll be able to determine how many APs you need.
Next, Cisco has a lot of models for the AP. I recommend you go here: http://www.cisco.com/en/US/products/ps5678/Products_Sub_Category_Home.html
Search for the AP you are interested in. I would recommend you DO NOT pick the 1600.
For the WLC, since you won't need anything in excess of 75 APs, I'd recommend you look into the WLC 2504.
01-13-2014 12:48 PM
All I can think I need 3 but I would try to buy two see if they cover both floors.
01-13-2014 01:22 PM
Is there any way I could do survey myself?
I am based in Lancashire (UK).
01-13-2014 01:50 PM
If you don't know what you are doing, how can you do a wireless site survey yourself?
If you'd like, get a floor done and watch (and learn) the person doing it like a hawk. If you are confident enough, do the second floor yourself.
There are a lot of UK-based authorized Cisco reseller. All you have to do is look for them youself.
One key bit when you are asking for a quote: It is very, very important you SPECIFICALLY tell the vendor the country you will want to install the AP. This is very important because if you or the vendor gets the wrong regulatory domain, you MAY NOT be able to get your AP to become operational.
01-13-2014 01:57 PM
What is the other option? Single APs on each floor without WLC. It would not harm if it works if not we only have to invest in WLC.
One thing I would like to ask can one AP provide both Guest and for employees?
01-13-2014 03:13 PM
Of course it can. Nearly everyone asks this scenario in the wireless forum.
01-13-2014 11:17 PM
Is there a good AP you could think of, if it does not achieve our goal then we could go for WLC and use same AP.
01-13-2014 11:58 PM
Mohammed,
Read my first response to this thread. It will contain a link of all available AP models and my recommendation.
