04-12-2012 07:12 AM - edited 07-03-2021 09:59 PM
I need to connect 2 remote offices about 50 yards disance.
I would like to ask if there is cisco AP solution so that I could bridge a group of VLAN trunks
on a WiFi conection, I would like to bring a certain number of VLAN trunks to the remote office
using WiFi Connection.
Is it possible in some way ?
thank you
Rick
04-12-2012 07:22 AM
Yes this is possible. For that short of a distance you could use the 1262 running IOS to get this done.
Steve
04-12-2012 01:30 PM
As Stephen mentioned, yes you can.
Get a couple of autonomous IOS 1262 AP's with external antenna
Set one up as the root bridge (the one connected to the main LAN) and set up the remote end as a bridge.
The connectivity to the LAN is by way of trunk ports so you can send multiple VLAN's across the wireless bridge
Good luck
04-12-2012 01:35 PM
Keep in mind, the 1260 TX @ 200mW and Cisco will only offically support up to 6 dBI max on anetnnas. Just an FYI
