Windows phones unable to connect to WLC
Hi all,
When we try to connect any windows mobile to wlc (code-7.2.103.0), it doesnt connect and stay in '802.1X REQD' status. What could be the issue.?
SSID settings
WPA+WPA2, AES, 802.1X security.
MFP is "optional"
I have also attached the debug logs.Quick response is appreciated.
Hall of Fame Super Silver
802.1X REQD means that the
802.1X REQD means that the layer 2 authentication has failed.  I would look at the radius server to see what failed and how it failed.  Might just be an issue with how windows mobile is trying to authenticate.
Post your show wlan <wlan id>
-Scott
Is there any bug to this
Is there any bug to this current version..?  coz all others are working fine..?
VIP Purple
It's looks like "Access-Reject" is getting for this client from RADIUS server
*Dot1x_NW_MsgTask_0: Mar 10 16:54:43.369: a8:44:81:2b:d0:08 Entering Backend Auth Response state for mobile a8:44:81:2b:d0:08
*Dot1x_NW_MsgTask_0: Mar 10 16:54:43.373: a8:44:81:2b:d0:08 Processing Access-Reject for mobile a8:44:81:2b:d0:08
*Dot1x_NW_MsgTask_0: Mar 10 16:54:43.373: a8:44:81:2b:d0:08 Removing PMK cache due to EAP-Failure for mobile a8:44:81:2b:d0:08 (EAP Id 6)
*Dot1x_NW_MsgTask_0: Mar 10 16:54:43.373: a8:44:81:2b:d0:08 Sending EAP-Failure to mobile a8:44:81:2b:d0:08 (EAP Id 6)
*Dot1x_NW_MsgTask_0: Mar 10 16:54:43.373: a8:44:81:2b:d0:08 Entering Backend Auth Failure state (id=6) for mobile a8:44:81:2b:d0:08
*Dot1x_NW_MsgTask_0: Mar 10 16:54:43.373: a8:44:81:2b:d0:08 Setting quiet timer for 5 seconds for mobile a8:44:81:2b:d0:0
This is happening multiple time & then it hit "max-AAA failure" condition
*Dot1x_NW_MsgTask_0: Mar 10 16:55:10.663: a8:44:81:2b:d0:08 Scheduling deletion of Mobile Station:  (callerId: 9) in 10 seconds
*Dot1x_NW_MsgTask_0: Mar 10 16:55:10.663: a8:44:81:2b:d0:08 Max AAA failure for mobile a8:44:81:2b:d0:08
*Dot1x_NW_MsgTask_0: Mar 10 16:55:10.663: a8:44:81:2b:d0:08 Setting quiet timer for 5 seconds for mobile a8:44:81:2b:d0:08
*Dot1x_NW_MsgTask_0: Mar 10 16:55:10.663: a8:44:81:2b:d0:08 dot1x - moving mobile a8:44:81:2b:d0:08 into Unknown state
*osapiBsnTimer: Mar 10 16:55:15.521: a8:44:81:2b:d0:08 802.1x 'quiteWhile' Timer expired for station a8:44:81:2b:d0:08 and for message = M0
*osapiBsnTimer: Mar 10 16:55:20.521: a8:44:81:2b:d0:08 apfMsExpireCallback (apf_ms.c:589) Expiring Mobile!
If you are usnig ACS as RADIUS check the ACS logs detail to see exact reason for AUTH failures
Rasika
*** Pls rate all useful responses ****
199
