Wired guest lan authentication through NGS
Hello Guys,
We have 5508 controller running ver 7.2.110.0.We have configured wireless guest and wired guest WLAN profiles and assosicated necessary dynamic interfaces to it. The authentication for both wireless and wired guest is through Cisco NGS[NAC]. I have configured Webauth and added the server in the security tab for authentication. I have guest user accounts created in NGS, if I use wirless guest the auth works perfect. But the same credentials is not working with wired guest. Any advice on this issue would be really helpful
Krishna
Everyone's tags (3)
Hall of Fame Super Silver
Re: Wired guest lan authentication through NGS
Your using NGS as a radius server only correct? If so, you should see errors generated on the NGS or the WLC to why the login failed. Does a different username work?
-Scott
Hey Scott,
Yes NGS is working as Radius. However I haven't checked on WLC neither NGS log to see if there is any but let me look into that. No other names also doesn't work. I did run a debug on WLC while the user was authenticating below is the output
Output of debug for wireless user where I am getting Accept message for auth at the end
User IP ADDR - 172.22.207.157
*aaaQueueReader: Aug 20 09:44:29.940: 00:23:14:ec:3d:38 Successful transmission of Authentication Packet (id 190) to 194.156.169.111:1812, proxy state 00:23:14:ec:3d:38-00:01
*aaaQueueReader: Aug 20 09:44:29.940: 00000000: 01 be 00 a2 cd 8f 91 44  a2 4f 85 f1 04 f7 14 9a  .......D.O......
*aaaQueueReader: Aug 20 09:44:29.940: 00000010: d0 3e 42 94 01 1b 6d 61  68 65 62 6f 6f 62 2e 6b  .>B...maheboob.k
*aaaQueueReader: Aug 20 09:44:29.940: 00000020: 68 61 6e 40 61 6d 61 64  65 75 73 2e 63 6f 6d 02  han@amadeus.com.
*aaaQueueReader: Aug 20 09:44:29.940: 00000030: 12 34 fc 96 01 47 ed 5e  d3 8d 08 4e 72 ce 1d b5  .4...G.^...Nr...
*aaaQueueReader: Aug 20 09:44:29.940: 00000040: da 06 06 00 00 00 01 04  06 ac 16 cf 83 05 06 00  ................
*aaaQueueReader: Aug 20 09:44:29.940: 00000050: 00 00 0d 20 0b 42 4c 52  57 4c 43 4f 30 31 3d 06  .....BLRWLCO01=.
*aaaQueueReader: Aug 20 09:44:29.940: 00000060: 00 00 00 13 1a 0c 00 00  37 63 01 06 00 00 00 01  ........7c......
*aaaQueueReader: Aug 20 09:44:29.940: 00000070: 1f 10 31 37 32 2e 32 32  2e 32 30 37 2e 31 35 37  ..172.22.207.157
*aaaQueueReader: Aug 20 09:44:29.940: 00000080: 1e 10 31 37 32 2e 32 32  2e 32 30 37 2e 31 33 31  ..172.22.207.131
*aaaQueueReader: Aug 20 09:44:29.940: 00000090: 50 12 ef 00 53 8b 39 31  14 93 b3 82 1c f5 b5 51  P...S.91.......Q
*aaaQueueReader: Aug 20 09:44:29.940: 000000a0: 82 45                                             .E
*radiusTransportThread: Aug 20 09:44:30.516: 00000000: 02 be 00 1a 0c 8e d4 54  91 55 d6 ae b2 91 05 6e  .......T.U.....n
*radiusTransportThread: Aug 20 09:44:30.516: 00000010: 93 f9 4b 7e 1b 06 00 21  70 70                    ..K~...!pp
*radiusTransportThread: Aug 20 09:44:30.517: ****Enter processIncomingMessages: response code=2
*radiusTransportThread: Aug 20 09:44:30.517: ****Enter processRadiusResponse: response code=2
*radiusTransportThread: Aug 20 09:44:30.517: 00:23:14:ec:3d:38 Access-Accept received from RADIUS server 194.156.169.111 for mobile 00:23:14:ec:3d:38 receiveId = 0
But for wired user below is the output
User IP ADDR - 172.22.207.151
5.338: 00:26:b9:e0:36:a6 Successful transmission of Authentication Packet (id 188) to 194.156.169.111:1812, proxy state 00:26:b9:e0:36:a6-00:01
*aaaQueueReader: Aug 20 09:35:15.338: 00000000: 01 bc 00 a2 2c fe c1 97  a7 d1 25 a0 59 34 89 38  ....,.....%.Y4.8
*aaaQueueReader: Aug 20 09:35:15.338: 00000010: c1 be 59 f3 01 1b 6d 61  68 65 62 6f 6f 62 2e 6b  ..Y...maheboob.k
*aaaQueueReader: Aug 20 09:35:15.338: 00000020: 68 61 6e 40 61 6d 61 64  65 75 73 2e 63 6f 6d 02  han@amadeus.com.
*aaaQueueReader: Aug 20 09:35:15.338: 00000030: 12 37 c7 5c 52 27 41 5b  0d 60 98 70 76 3b b3 ba  .7.\R'A[.`.pv;..
*aaaQueueReader: Aug 20 09:35:15.338: 00000040: f5 06 06 00 00 00 01 04  06 ac 16 cd 74 05 06 00  ............t...
*aaaQueueReader: Aug 20 09:35:15.338: 00000050: 00 00 0d 20 0b 42 4c 52  57 4c 43 4f 30 31 3d 06  .....BLRWLCO01=.
*aaaQueueReader: Aug 20 09:35:15.338: 00000060: 00 00 00 0f 1a 0c 00 00  37 63 01 06 00 00 02 02  ........7c......
*aaaQueueReader: Aug 20 09:35:15.338: 00000070: 1f 10 31 37 32 2e 32 32  2e 32 30 37 2e 31 35 31  ..172.22.207.151
*aaaQueueReader: Aug 20 09:35:15.338: 00000080: 1e 10 31 37 32 2e 32 32  2e 32 30 35 2e 31 31 36  ..172.22.205.116
*aaaQueueReader: Aug 20 09:35:15.338: 00000090: 50 12 36 60 54 47 0b 84  02 5c 0b da 19 a1 05 eb  P.6`TG...\......
*aaaQueueReader: Aug 20 09:35:15.338: 000000a0: af 2b                                             .+
*aaaQueueReader: Aug 20 09:35:17.053: AuthenticationRequest: 0x2ab12b50
You need to look at the logs.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Hey Scott,
I did look into the logs in WLC it says that the Radius was not able to authenticate the user and mentioned the laptop's ethernet mac addr and the reason it shows as unknown
Krishna
355
