Wireless 3850 and Web-Auth for Wireless clients
I can't get the web-auth feature to work properly on the Catalyst 3850 for wireless clients.
Internet is all tested and there is full IP connectivity.
Issue is when I enable the webauth feature on the SSID. Incidentally when I enable the SSID to use consent it works.
I am using local authentication for the guest users.
When user logs onto the wireless, they get to the landing page, and are able to enter the credentials then there is a 30 second pause. The client detail says WEBAUTH_PEND and then a pop up window comes back as seen below
Config below
interface Vlan302
description **** Wireless Guest ****
ip address 10.145.224.161 255.255.255.224
ip helper-address 10.144.214.134
ip helper-address 172.17.2.56
ip http server
ip http secure server
ip dhcp snooping
wlan XXXXX 2 XXXXXX
aaa-override
accounting-list default
client vlan 302
ip flow monitor wireless-avc-basic input
ip flow monitor wireless-avc-basic output
no security wpa
no security wpa akm dot1x
no security wpa wpa2
no security wpa wpa2 ciphers aes
security dot1x authentication-list WEB_AUTH
security ft
security web-auth
security web-auth authentication-list WEB_AUTH
security web-auth parameter-map vit_web
no shutdown
parameter-map type webauth vit_web
type webauth
user-name Guest1
creation-time 1390837878
privilege 15
password 7 022D0156060F1B351D
type network-user description Temp-Guest-User guest-user lifetime year 0 month 1 day 0 hour 0 minute 0 second 0
user-name Guest2
creation-time 1390838016
privilege 15
password 7 0724244143000D1145
aaa new-model
aaa authentication login WEB_AUTH local
aaa authorization network WEB_AUTH local
VIP Purple
Hi Greg,
These post should helps you
1. https://supportforums.cisco.com/docs/DOC-34454
2. https://supportforums.cisco.com/docs/DOC-34455
3. 5760/3850 Web Passthrough Configuration Example
Rasika
**** Pls rate alll useful responses ****
Thanks for the references, but I am still unable to get this working with local Web-Authentication.
I can get this working when I select "consent" in the authentication parameter map but when I enable the Web-Auth feature this fails everytime.
I have been through these documents several times and the configruations I have are identical.
Hey Greg,
Did you also define the global webauth parameter? I think I had to do this to get my 5760 "working" or as working as these new controllers can be.
parameter-map type webauth global
type webauth
virtual-ip ipv4 x.x.x.x wlc.whatever.org
max-http-conns 50
Also I had to enable http server in addition to secure server
ip http server
ip http secure-server
Are you using a self signed cert?
I saw windows clients take a long time to load the page when using a self signed cert.
MAC clients dont seem to work if you use the IOS or OSX based logon. You'll need to disable the auto logon and launch a browser for the redirect. There was a bug ID around this MAC problem which was supposedly resolved in 3.3.1SE  but I still have the problem.
-Kyle
Change
to:
aaa authorization network default local
976
