02-01-2006 06:46 AM - edited 07-04-2021 11:34 AM
Hi Wireless Lan controller 4400 the documnetation on this product is awfull . I am trying to configure wpa-2 using 802.1x authentication or leap is this possable as for web interface cannot find were you set authentication type. if wpa-2 uses a particular type what is it. Probably a very dumb question but these option apper to be availble on all airnet products
02-07-2006 07:52 AM
Web authentication enhancements extend the total number of characters on Web authorization customization to 500 characters. The user can also use a "submit" button instead of a full user name / password challenge. A third enhancement allows Wi-Fi Protected Access/Pre-Shared Key (WPA/PSK) and WPA2/PSK to work with Web authentication. These enhancements provide more flexibility in deploying wireless networks with Web authentication.
Wireless LAN Controllers supported: Cisco 2000, 4100, and 4400 Series
Access points supported: Cisco Aironet 1010 and 1020 Series lightweight access points
http://www.cisco.com/en/US/products/ps6366/prod_bulletin0900aecd802d2742.html
03-05-2006 05:06 PM
In the controller, you navigate to the WLAN page, where you name the SSID etc. On the upper right of the page is the L2 security options drop down box, below that the L3 options.
04-19-2006 09:59 PM
On the SSID page : go to L2 and select WPA-2
at the bottom of the page : verify that the box Passphrase is NOT checked and voila it's WPA-2+802.1X
since it's not WPA-2+PSK(passphrase)
GB
04-20-2006 03:29 AM
THANKS
WILL TRY
eDDIE
