02-25-2009 08:07 AM - edited 07-03-2021 05:13 PM
Is it possible to deploy TACACS on a VxWorks wireless AP?
If so, how? Is there a link to such a configuration?
I found a Cisco link to configuring the AP in its entirety, but I dont see anything about TACACS.
Victor
02-25-2009 08:48 AM
TACACS is a Cisco-proprietary protocol and likely was never added to VxWorks, though I can't speak from experience.
What device are you using? Aironet 350s can be upgraded to IOS. If you're using 340s, though, you might be stuck without it.
02-25-2009 08:55 AM
Jeff, I think its a mixture of 350s and 1200s.
I know these devices can use a CLI, although I have never used it.
[EDIT] When I say CLI, I dont mean Cisco CLI (IOS), just a general CLI in addition to a browser interface. [EDIT]
Are you saying that these APs can have Cisco IOS loaded on them, as the Cisco 1242s? If the answer is yes, then of course I can see how TACACS can then be added.
By the way, I know TACACS is Cisco proprietary.
02-25-2009 09:14 AM
Hi Iamav,
Yes, 1200s and 350s can be upgraded to IOS. VxWorks has a menu-driven CLI, so it's far from intimidating.
This document shows how to upgrade a 1200:
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_tech_note09186a008019fea0.shtml
02-28-2009 07:34 AM
Thanks, Jeff.
