Wireless Bridge - Nosferatu command?
Configuring some bridges today... doing some testing... went to run a Linktest between the 2 bridges and see a "nosferatu" command...???
ROOT_BRIDGE#dot11 dot11Radio 0 ?
  bfmr              Set radio FW CVBF beamformer flags
  carrier           Carrier detect test
  channel-set       Set channel
  cvbf              CV Beamforming <enable|disable>
  edca-parameters   Configure custom edca parameters
  linktest          test the radio link
  nos               nosferatu
  packet-send-loop  Send packet in a loop
  packet-send-one   Send one packet
  radio-reset       radio reset
  update-group-key  Update Group Key
  vhtopmode         Send VHT Action Op Mode
ROOT_BRIDGE#dot11 dot11Radio 0 nos ?
  set-TH  set threshold
ROOT_BRIDGE#dot11 dot11Radio 0 nos set ?
  <0-1000>  value in usec
ROOT_BRIDGE#dot11 dot11Radio 0 nos set 1000 ?
  <cr>
Curiosity got me looking online for what this might be and, other than Vampire hits, I was not able to find any description of what this is.
Anybody know?  Not that I need to know what it is... just more of curiosity thing and that I like to understand as many commands and settings as possible...
Thanks!
Are these 1532s by chance? By
Are these 1532s by chance? By guess and its only a guess is this has something to do with carrier sense.
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
I reached out to Aaron
I reached out to Aaron Leonard and a couple others to see if they can weigh in on what this means.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Yes, great guess! They are
Yes, great guess! They are 1532i's.
They are running 15.2(4)JB5
Well if they are 1532's then
Well if they are 1532's then they can't take a WSSI model, so this command should do nothing.
If this bothers you, you can open a TAC case and ask the TAC engr to file a bug to have this command removed or hidden.
Cheers,
Aaron
No really an issue, just more
Not really an issue, just more of a curiosity and I knew this would be the best place to ask.
No big deal... thanks for everybody's help and input though!
What type of AP and what code
What type of AP and what code version are you running?
I took a look at my 1142 running 12.4-25.JA2 and I don't see the nosferatu command
They are 1532i's and I have
They are 1532i's and I have Autonomous code on them.  15.2(4)JB5
"nosferatu" was the code name
"nosferatu" was the code name for the WSSI module.  Guess this is some detritus from the development work.
125
