Community Member
Wireless Bridges-Info
David,
At Bad remote,in the Network Stats when you click on the Bridge Radio, there are 5940 CRC errors and rising.
On the Root Bridge same stats show only 36 CRC errors.
I also have a TAC case open now.
Bob
Re: Wireless Bridges-Info
Bob,
A TAC case is a great idea in this case.
If you are seeing lost of CRC errors on one end only then I susspect you have a problem with your coax or one of the connectors are lose.
The other problem that you could have is the Antenna placement If the Antenna is mounted back from the edge roof it is possible that the roof is in your Fresnel zone I am sure the TAC will help you find this.
A small suggestion to make the most out of this forum is if it is all related to one problem then use the reply button instead of posting a new topic. People may miss your reply if it is in a new post.
Community Member
O.K.
Bob
180
