Community Member
Wireless Bridging to Out Buildings
I need to extend my LAN to an out building that is approx. 3000 feet away. What is recommended to achieve this?
Green
Re: Wireless Bridging to Out Buildings
Any of the current bridges with directional antennas should be able to handle 3000 feet without any problems (as long as you have clear line-of-sight).
Something like a 1310 would be fine (as long as you have clear line-of-sight).
Good Luck
Scott
Community Member
As suggested correctoly by Scott go for 1310 Bridge with AIR-ANT1949 yagi mast mount antenna which has a range up to 2.27 Km @ 54 Mbps.
All the Best
Sushil
248
