wireless design for lwapp in warehouse
Hi all, Im planning on putting wireless in my warehouse over the next month, we have had a survey and we need 11 ap's and a controller, my question is, should we have a backup controller as the wireless is critical to the business here ? i was told to use 1240 access points and a 4402 controller, what do you guys think ?
Re: wireless design for lwapp in warehouse
Yes, a backup controller would be beneficial for a mission critical wireless deployment. a 4402 will work fine for 11 APs. personally, I would add a few more and either keep them in monitor mode or lop off some of the basic-rate levels in 802.11 (think more, smaller cells vs fewer, larger ones).
The 1240s are nice, but they will not do 802.11n (pre-draft)
Hall of Fame Super Silver
The 1240's with two 4402-25... one for backup should be fine. How high up are the antennas going to be placed?
If you do decide to look into the 1250. You will need three antennas instead of two. Also you will probably have Rf scanners, which I don't think support MIMO or 'N'.
-Scott
Dear
Can you tell me the length and width for this warehouse, please? And if you use dipole antennas you will have a lot of interference problem
223
