09-18-2002 11:11 AM - edited 07-04-2021 11:24 PM
We have implemented a single 350 AP with Cisco ACS 2.6. The problem is that the clients are able to associate and logon through the radius server, but never receive an ip address. The clients are W2K and XP. Any thoughts on what the problem might be or how to configure the radius server properly to give out ip's to the wireless clients?
09-25-2002 10:38 AM
One thing to check is that if you are using WEP with LEAP then you need to make sure that the keys are the same on the client and the AP. Try upgrading the firmware on the AP as this can be an issue for DHCP.
09-25-2002 10:44 AM
Thank you for your reply. However, I have discovered the problem. The access point had the aironet extensions disabled, but MIC and TKIP were configured and enabled. This was preventing me from communicating properly. As soon as I enabled the aironet extensions, things started to work properly.
