06-20-2006 06:03 AM - edited 07-04-2021 12:24 PM
Hi, I am trying to get my 870 router to assign DHCP addresses to wireless clients. The wired LAN works fine. If I assign a static address to my laptop it seems to work fine. Just not DHCP.
I have posted my config.....
Any comments appreciated
06-20-2006 07:50 AM
Nicholas, the problem I see is that you are using a second vlan, and you do not have it defined in the router. Try this:
interface Dot11Radio0
no ip address
encryption vlan 2 mode ciphers tkip
ssid Home
vlan 2
authentication open
authentication key-management wpa
wpa-psk ascii xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan2
description Wireless
no ip address
bridge-group 1
interface BVI1
ip address 10.252.12.1 255.255.255.0
ip nat inside
ip virtual-reassembly
Added a VLAN2 interface that is in bridge group 1, and set the SSID to be in vlan 2, also changed the encryption command to encrypt vlan 2.
06-29-2006 05:12 AM
In the conf mode on router run the is helper command & give the ip address of the dhcp server.
06-29-2006 06:16 AM
You should remove "ip nat inside" from vlan 1 config and put "bridge-group 1" under vlan 1 config.
