wireless hosts issue
I have a Cisco 851 configured to support both wireless and wire networks with different dhcp pools. Router is configured with irb and on bridge group 1
Wireless network = 192.168.1.0
Wired network 192.168.0.0
Problem
Hosts A = 192.168.0.17 is the media server with shared files..ready for hosts B = 192.168.1.35 to grab. Hosts B is a Sony PS3 game console. Hosts A can ping hosts B, and i can ping hosts B with the BVI1 interface for the Dotradio0.1....
Hosts B uses port 1900 (SSDP - unicast/multicast...
If i try to connect to the media server, i get error message, and the media server is learning the mac address of the sony system.
I think "bridge-group 1 block-unknown-source" on the dotradio0.1 is blocking the traffic for 1900 but i cannot remove it since its and irb statement. Naing the sony, it doesn't show up in the router.
Help.
bridge irb
interface Dot11Radio0.1
description open keymaster
encapsulation dot1Q 1 native
ip broadcast-address 192.168.1.255
ip helper-address 192.168.1.17
ip helper-address 192.168.1.255
no ip redirects
ip local-proxy-arp
no ip route-cache
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface BVI1
ip nat inside
ip virtual-reassembly
no ip mroute-cache
ip forward-protocol nd
ip forward-protocol udp 1900
ip route 0.0.0.0 0.0.0.0 FastEthernet4
Dot11Radio0 unassigned YES NVRAM up up
Dot11Radio0.1 unassigned YES unset up up
FastEthernet0 unassigned YES unset up up
FastEthernet1 unassigned YES unset up up
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up down
FastEthernet4 .... YES DHCP up up
Vlan1 192.168.0.1 YES NVRAM up up
NVI0 unassigned YES unset administratively down down
BVI1 192.168.1.1 YES NVRAM up up
Silver
Re: wireless hosts issue
Haha, this must be a home network of some kind. Trying to get a PS3 to access a media server is rarely a business issue ;)
What strikes me as odd is that the media server is learning the MAC address of the PS3. MAC addresses should never leave a subnet, so it sounds like we have a routing problem.
Can you post your entire config? Also post a "show ip route". It looks like VLAN 1 is the 192.168.0.0 subnet, but BVI1 is the 192.168.1.0 subnet. I believe that you might have BVI1 configured to map to VLAN 1, which would effectively combine the subnets. It should still pass traffic (and indeed it does by the ping test), but it might be causing your clients some grief.
Out of curiosity, do you have another AP that you could use to connect your PS3? Even if it's just a LinkSys or something, it'd be good to ensure that the wireless router is indeed the problem.
Yes, vlan1 and bvi1 are both mapped with irb - bridge group 1
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
24.0.0.0/22 is subnetted, 1 subnets
C 24.163.36.0 is directly connected, FastEthernet4
10.0.0.0/32 is subnetted, 1 subnets
S 10.127.32.1 [254/0] via 24.163.36.1, FastEthernet4
C 192.168.0.0/24 is directly connected, Vlan1
C 192.168.1.0/24 is directly connected, BVI1
S* 0.0.0.0/0 is directly connected, FastEthernet4
GateKeeper#
ip dhcp pool HOSTPOOL
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
ip dhcp pool WIRELESS
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip domain lookup
archive
log config
hidekeys
ip ssh version 2
bridge irb
bridge mac-address-table limit 300
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description ROADRUNNER
ip dhcp client update dns server both
ip address dhcp
no ip proxy-arp
ip nat outside
no ip mroute-cache
duplex auto
speed auto
no cdp enable
description KeyMaster
no ip address
no ip route-cache cef
no ip route-cache
ssid KeyMaster
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
packet retries 20
channel least-congested 2437 2442 2447 2452 2457 2462
station-role root access-point
world-mode legacy
no ip redirects
ip local-proxy-arp
no ip route-cache
no cdp enable
bridge-group 1
bridge-group 1 spanning-disabled
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
no ip virtual-reassembly
interface BVI1
ip nat inside
no ip mroute-cache
I do not have another AP..
I also want to add that the PS3 can get out to the internet, the media server can ping the PS3 when on the Wire network(but cannot when on the wireless)
And that the main problem is for the PS3 to be able to access shared files on the media server...any help will be appreciated.
Silver
I see that you have NAT configured on both your BVI and VLAN 1 interfaces. NAT should only be configured on your Fa4 interface for routing out to the Internet. You shouldn't need NAT for routing traffic internally.
Can your PS3 connect to anything else on the wired network when on the wireless interface? Can any other wireless client connect to the wired network while on the wireless?
222
