You might want to think about procuring something like a Cisco 4402 controller to use as a mobility anchor. You can take all guest traffic (wireless, and wired, if you want) and tunnel it through the anchor to your other/guest ISP.
If you are planning on using H-REAP for your remote sites, then I'm not sure how/if a mobility anchor would fit in to such a configuration.
