Community Member
Wireless LAN controller
I have Cisco wireless controller on site A and connected with 1600 series access point.On my site b I have 1600 series access point no WLC .How to connect these access point over the wan. I want my authentication traffic goes to the controller.
Everyone's tags (1)
Hall of Fame Super Blue
Yes you can.  It's called
Yes you can.  It's called FlexConnect.
FlexConnect Feature Matrix
Configuring FlexConnect
Check the link ; http://www
Highlighted
It is possible,. this is
It is possible,. this is Flexconnect mode, previously know as Hybrid Remote Edge Access Point or H-REAP
Please refer to the below url
Please refer to the below url that will help you to connect two different sites.
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/112042-technote-product-00.html
192
