Wireless Phone 7921G
hi all,
We are trying to authenticate cisco 7921G wireless phone through EAP-TLS..
getting error message in ACS server
EAP-TLS or PEAP authentication failed during SSL handshake
but EAP-TLS works fine with same ACS server when user machine is connected.
please let us know if any particular service need to be enabled in cisco 7921G(other than choosing in profile) to make it work
thanks in advance
Hall of Fame Super Silver
Re: Wireless Phone 7921G
Have you followed the steps in this doc?
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/6_0/english/administration/guide/7921cfgu.html#wp1376129
-Scott
hi, yes correct.this specifics are followed, one thing need to clariy the CM placed different site location and once this device is reqistered with CM..im unable to edit the phone time to local time,its automatically taking the CM time.
Now after restarting the ACS server service.in ACS server log seeing"internal error"
thanks
That is not good. Restart the server and see if it comes back up clean.
-Scott
hi, i did restart the ACS server now..getting same error.
is there something to do with ACS server v3.3?
thanks
adding the error detail
Date Time Message-Type User-Name Group-Name Caller-ID Authen-Failure-Code Author-Failure-Code Author-Data NAS-Port NAS-IP-Address
06/28/2008 14:17:05 Authen failed CP-7921G-SEP001D451BEFDC VoIP group 00-1D-45-1B-EF-DC Internal error .. .. 29 139.95.122.3
one more thing observed is, in ACS server, the manufactured CA root certificate loaded in ACS server and checked in edit trust list.
but in certificate revocation list..that root is displayed as not in use.
CRL Issuers
Issuer Friendly Name Status
Cisco Manufacturing CA Not in use
while edit to make it used it asking for CRL Distribution URL..where can i get this URL?
thanks
Are you still getting errors from your first post. SSL handshake fails?
-Scott
hi, im no more getting that error..only getting the internal error..even after server reboot.
thanks,
240
