Community Member
wireless site survey planner tool for multi floor office building
I'm looking a wireless site survey planner tool for multi floor office building to estimate the number of APs and location. Not the site survey after install APs.
AigMagnet is excellent for single floor but cannot provide multi floor scenario via planner feature even it merging capable with site survey after APs installation.
Any tools can provide the planner tool for multi floor office building?
Thanks in advance,
Community Member
Re: wireless site survey planner tool for multi floor office bui
Ekahau latest version can do 3D planning. Follow the link for more info:
http://www.ekahau.com/products/ekahau-site-survey/overview.html
Cj
If you are looking for an AP estimate you can simply do the sq feet divided into the grade of wireless. For example
You have a 100,000 feet building. All 100,000 sq feet will be wireless.
Data 5,000 - 6.000 sq feet per AP or 100,000 / 5,000 = 20 access points
VoIP 2,500 sq feet per AP or 100,000 / 2,500 = 40 access points
I always like to pad it by another 10%.
I hope this helps …
718
