Wireless to Wireless - No connectivity
I have a Cisco 871W, config attached, with connected LAN desktops and WLAN laptops and 1 WLAN printer. The desktops have no issue sending print jobs to the printer but I'm unable to do so with the laptops. I can ping LAN to WLAN but I'm unable to ping WLAN to WLAN. I've searched Cisco and haven't been able to determine the solution. Any help would be appreciated. IOS v. 870 AdvSecurity 12.3(8)YI2
The second issue I have is passing the SSH protocol from a client on the Internet through the router to the SSHD server residing on FastE1 with IP address 192.168.0.100. I turned off SSH on the VTY but the router doesn't appear to be passing the packets through to the server. Also any help would be greatly appreciated.
1 REPLY
Green
Re: Wireless to Wireless - No connectivity
You may want to check your setting for "Public Secure Packet Forwarding." PSPF prevents a wireless client from communicating with other wireless clients in the same system (this is a protection mechanism for "hotspots" and other public wireless).
Good Luck
Scott
118
