10-10-2014 05:52 AM - edited 07-05-2021 01:42 AM
Hi all,
I am planning an upgrade of a 5508 WLC with all APs in FlexConnect mode. The APs do not have a primary, secondary, or tertiary controller configured under the High Availability tab per AP. I know APs should join the controller to which they were previously associated upon a reboot, but does this still hold true once the AP software is upgraded as well?
Thanks in advance for your replies!
Solved! Go to Solution.
10-10-2014 07:08 AM
Yes..Basically they should remember the WLCs which they know before the upgrade.
To check about the WLCs which they know ? Use ..."sh capwap client config" on the AP.
Dhiresh
10-10-2014 07:08 AM
Dhiresh
