hi all
CIsco AP 1100 support IOS and vlan how does this works
Does AP 1100 support VTP?
Does AP 1100 support DTP?
IF VTP is supported does it means than if i have vlan 5 named foo in my switched network i will have a ssid foo
created automatically or should i have to config a manual mapping between ssid and vlan name?
In 802.11 I (chiffering) will be done via AES algo.
for clients compatibility, will an AP support the two algo (AES and 128 bit RC4 wep)?
in futur will pcmcia support the two ciffer technique too?
how will it be possible to upgrade AP and pcmcia to support AES because ciffering
is hardware supported actually?
Thanks for any info
regards
Alain
