You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
Wireless
What configuration is required to connect 1552S AP to Cisco 5500 controller. Sometimes I am learning two mac on the connected interface and the mac is not forwarding to core.
  • Other Wireless - Mobility Subjects
1 ACCEPTED SOLUTION
Hi, Ok ,,this is Lwapp AP.Int
Int bvi1
no ip address
int gi 0
no ip address
To enter in to Configuration mode
debug capwap con cli
Dhiresh
Please rate helpful posts
VIP Purple
HI Anuj,Did you configure the
HI Anuj,
Did you configure the WLC with right interface and right WLAN?
Did you connect AP to swicth with correct port configuration?
Did you configure atleast method for AP to connect WLC?
Check this link for basic WLC and AP configuration: http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/69719-wlc-lwap-config.html
Dont forget to rate helpful posts
All other AP's are working
All other AP's are working fine, I am having problem with few of the 1552S AP. I have 6 of them installed in my network with 2 of them working (by adding their mac address under AP Policies). The rest of the four AP are not joining when I am following the same process.
Also the strange thing is the 2 1552S AP which are working , I am learning two mac address on the connected interface wheres for rest of the 4 AP I am learning only one and they are not working.
Also the learnt mac address is different from what is labelled on the hardware.
VIP Purple
I will say. Check again the
I will say. Check again the right mac address of the AP and add in Secirity>AP policies.
If still fails then reboot AP and paste the complete logs from console access
REgards
What should I check in AP
What should I check in AP console, two of the AP of similar type is working but not rest 4. I am setting them as outdoor AP's and this is the first time I am working on 1552s AP. Please help.
VIP Purple
Hi Anuj,Lets start from basic
Hi Anuj,
Lets start from basic because there are bit confusion regarding RAP or MAP.
1.Are you trying to use rest 4 AP as MAP ?
2. Did all AP fisrt connected to WLC ??
I would recommand:
1. First connect all AP to WLC (By adding there mac address to either MAC filter option or under AP policies.)
If you are using mac filter then choose Any WLAN and interface as management.
I took the console of the AP
I took the console of the AP and the AP is already having BVI1 and GI0 configured with ip address from another vendor and also having a default gateway configured. Any idea on how to remove those configurations so that it can pick up ip from the new controller?
Hi, Look like it is an
Look like it is an Autonomous AP which doesnt need Controller.
Do "sh version"..If it is AP3G1-K9W7-M..W7 then it is Autonomous. If that is the case then you will have to download AP lwapp image (full since this is Mesh)..and push in to it and then reload.That should look like AP3G1-K9W8-M...
Dhiresh
The AP model number is AIR
The AP model number is AIR-CAP1552SA-E-K9  . I guess the AP has static configuration, Is there any way by which I can change it to dynamic and remove the ip from Gi0 and BVI1 interace and also the default gateway from the AP?
Hi Anuj, So you want to
Hi Anuj,
So you want to remove the IP address and gateway ..correct ?
Use the "no" version of the commands. Also can you paste "sh version" here?
Dhiresh
152
