WISM-1 Error
Hello:
I have a 6506-E Switch that was functioning in VSS Mode. I already clear this configuration and only have one switch with a Service WISM Module.
This is the output show wism status
#sh wism status
Service Vlan : 168, Service IP Subnet : 192.168.1.1/255.255.255.0
      WLAN
Slot  Controller  Service IP       Management IP    SW Version  Status
4     1           192.168.1.2      172.20.50.10     7.0.98.218  Oper-Up
4     2           0.0.0.0          0.0.0.0                      Service Port Up
sh ip int b | inc Port
Port-channel140        172.20.253.246  YES manual up                    up
Port-channel407        unassigned      YES unset  up                    up
Port-channel408        unassigned      YES unset  up                    up
The led Status on the Second Controller is "ORANGE"
What can be the problem.
I power down the module 4 and it doesn´t work.
The first Controller is working Properly.
What can be the problem??????????
Everyone's tags (4)
Hall of Fame Super Gold
WISM-1 Error
Console into the controller.  There's no IP addresses anywhere.
Silver
WISM-1 Error
a WISM1 has 2 controllers, so you have to configure the second one.
Posted by WebUser Erik Boss from Cisco Support Community App
Hall of Fame Super Silver
WISM-1 Error
Just to add.... take a look at this guide as it will explain how to setup your WiSM.  Like Leo and Web User mentioned, there are two separate WLC's in a WiSM1 and you also have to define your service port IP address.
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_tech_note09186a00808330a9.shtml
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Re: WISM-1 Error
Not relegated to your issue but I noticed your code is 7.0.98 .. Id recommend a higher code rev. .98 was problematic ..
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
WISM-1 Error
WISM consists of two independent controllers. Interfaces and ip addresses have to be considered on both cards independently. Use the following command to verify installation of both cards. Orange color of Stat. LEDs signifies booting is in process. Crossing temp threshold can also display orange color.
cat6506#show module
Mod Ports Card Type                              Model              Serial No.
  3   10  Wireless Service Module               WS-SVC-WISM-1-K9   SAD092504J8
  4   48  48-port 10/100 mb RJ45                 WS-X6148-45AF      SAL08154UT3
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3BXL     SAL0913827E
Mod  Online Diag Status
  3  Pass <>
  4  Pass
  5  Pass
185
