WiSM PortChannel Issue?
I'm running a WiSM on a 6504E using supervisor code s72033-ipservices_wan-mz.122-33.SXI2.bin. When I add a statement configuring the allowed VLANs on the WiSMs, I get the following errors:
*Aug 5 16:56:35.202: %EC-SP-5-CANNOT_BUNDLE2: Gi2/6 is not compatible with Po404 and will be suspended (trunk mode of Gi2/6 is dynamic, Po404 is trunk)
*Aug 5 16:56:35.826: %EC-SP-5-CANNOT_BUNDLE2: Gi2/5 is not compatible with Gi2/7 and will be suspended (trunk mode of Gi2/5 is trunk, Gi2/7 is dynamic)
*Aug 5 16:56:36.138: %EC-SP-5-CANNOT_BUNDLE2: Gi2/6 is not compatible with Gi2/8 and will be suspended (trunk mode of Gi2/6 is trunk, Gi2/8 is dynamic)
Keep in mind that I don't have the option to configure these gigabit interfaces as they are auto-provisioned by the version of code being run on the switch.
Here are some show commands that may be of interest:
###-###-mdf#sh etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use N - not in use, no aggregation
f - failed to allocate aggregator
M - not in use, no aggregation due to minimum links not met
m - not in use, port not aggregated due to minimum links not met
u - unsuitable for bundling
d - default port
w - waiting to be aggregated
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
403 Po403(SU) - Gi2/1(P) Gi2/2(P) Gi2/3(P)
Gi2/4(P)
404 Po404(SU) - Gi2/5(P) Gi2/6(P) Gi2/7(P)
Gi2/8(P)
###-###-mdf#show wism status
Service Vlan : 3015, Service IP Subnet : 10.139.255.1/255.255.255.0
WLAN
Slot Controller Service IP Management IP SW Version Status
2 1 0.0.0.0 10.137.139.2 5.2.178.0 Service Port Up
2 2 0.0.0.0 10.137.139.4 5.2.178.0 Service Port Up
###-###-mdf#show etherchannel load-balance
EtherChannel Load-Balancing Configuration:
src-dst-ip
mpls label-ip
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source XOR Destination MAC address
IPv4: Source XOR Destination IP address
IPv6: Source XOR Destination IP address
MPLS: Label or IP
Re: WiSM PortChannel Issue?
Do you have qos enabled globally? This was an issue with IOS a while back, but should be fine in SXI
how6506A#sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(33)SXI1, RELEASE SOFTWARE (fc3)
maybe they broke it again in SXI2
show6506A#sh mls qos
QoS is enabled globally
Policy marking depends on port_trust
QoS ip packet dscp rewrite enabled globally
Input mode for GRE Tunnel is Pipe mode
Input mode for MPLS is Pipe mode
QoS Trust state is CoS on the following interface:
Gi4/1 Gi4/2 Gi4/3 Gi4/4 Gi4/5 Gi4/6 Gi4/7 Gi4/8 Po407 Po408
Vlan or Portchannel(Multi-Earl) policies supported: Yes
Egress policies supported: Yes
ports listed in above command are my wism ports
Eric -
I turned on qos and set the trust to cos. I then issued the allowed-vlan command again with the same result.
Scott
can you try removing the wism configs from the switch and re-adding them both with qos disabled and then again with qos enabled?
640
