WiSM Reboot
a12288
Level 3
Level 3
We just go live 2 WiSM on 2 Cat6k core routers days ago, the WiSM runnint version is 4.0.155.5, while the Cat6k SUP720 running version is s72033-entservicesk9_wan-mz.122-18.SXF5.bin, somehow today we found 3 WLC reboos itself, TAC said other customers are facing similar issues? do you encounter this problem, and any workaround? thanks.
s.jankowski
Level 4
Level 4
hi, there.
can you give me some more details? upgrade the sup720 and/or WiSM or both, the latest code which is 4.0.179.8 still exposed to CSCsf27479.
did you have same issue and the upgrade fix it? thanks.
zhenningx
Level 4
Level 4
We have seen the same issue with wism 4.0.155.5. TAC said it is a known bug and no workaround for now. TAC also said the latest version 4.0.179.8 is also exposed to this bug. So we did not go for upgrade. Have anyone fixed this issue by upgrade?
