WiSM & WLC2504
hey,
maybe someone can help me with some difficulties that i have. i put a WLC2504 in my network to work at the same time with my WiSM, so both of then can work with the same mobilities groups. my questions are, if my WLC2504 can replicate the configuration of my WiSM, so if i make a chance the WLC can apply automatically the new configuration, and if that is possible how??? what do i need configure???.......or if i have cisco prime infrastructure, then, can i have a centralized configuration from both???
thank you in advice for your help and time
Christian
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Re: WiSM & WLC2504
There is no sync between your WiSM and the 2504. Changes have to be made on both WLC's.
-Scott
WiSM & WLC2504
Not really... PI can push out templates, but that doesn't mean a true sync.  Those are two different platforms and thus, you can't really sync the interfaces.  You can look at creating templates that you want to audit, but if your also running different code version, your looking at getting into trouble.  You need to manually make changes.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Re: WiSM & WLC2504
-Scott
WiSM & WLC2504
hi scott
thank you for your answer, but if i have cisco prime infrastructure, can i have a centralized configuration from both???, or there is any way that i can sync both devices??
thanks again
WiSM & WLC2504
Scott
-Scott
191
