WISM2 AND VRF ISSUES
Hello everyone,
I configured my WISM2, HA SSO also configured and everything working fine, but
My SVI interfaces for service and management vlans need to be included into VRF
interface vlan 301
desc service interface for wism2
ip address 10.30.1.254 255.255.255.0
interface vlan 302
desc management interface for wism2
ip address 10.30.2.254 255.255.255.0
Wism status is OPER-UP and everything is fine, but when i write
interface vlan 301
ip vrf forwading wism1
interface vlan 302
ip vfr forwading wism1
My two WISM2 are going to Keepalive state, and only service ip address in shown, like this
CORE-VSS#show wism status
Service Vlan : 301, Service IP Subnet : 10.30.1.254/255.255.255.0
      WLAN
Slot  Controller  Service IP       Management IP    SW Version    Controller Type    Status
26    1           10.30.1.1        0.0.0.0                       WS-SVC-WISM-2-K9   Started KeepAlive
42    1           10.30.1.2        0.0.0.0                       WS-SVC-WISM-2-K9   Started KeepAlive
What it can be, how can i fix it to work with vrf
thank you
Everyone's tags (1)
Hall of Fame Super Silver
Re: WISM2 AND VRF ISSUES
The service port should remain local to the WiSM2 and should not be routed. This is out of band and will cause issues if the service port has connectivity to the management.
-Scott
I want to understand, how can i connect my vrf instance with my wism2, for example
when i just ping 10.30.1.1 255.255.255.0 its not working
when i ping int like ping vrf ip 10.30.1.1 it works
So i cant see my wism2 cause of this vrf commands
thank you
You might be better off opening another post on the Routing forum. They can help you better with your VRF issue.
-Scott
206
