WISM2-Cannot Login via WEB
Hi everyone
I cannot login the wism2 with browser.
But I can use command to login the wism.
like this:
VSS-6509#session switch 2 slot 9 processor 1
The default escape character is Ctrl-^, then x.
You can also type 'exit' at the remote prompt to end the session
Trying 172.16.31.2 ... Open
User:admin
Password:*********
(WiSM-slot41-1) >
notice:Sometimes I can login via the web.The interface and ip address configuration were correct.
WISM2 log:
*emWeb: Mar 08 05:20:38.189: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 05:04:38.105: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 04:48:38.032: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 04:32:37.951: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 04:16:37.861: #CLI-3-LOGIN_FAILED: cliutil.c:653 Login failed. User:nouser, Service type:-8. excessive failed login attempts.
*emWeb: Mar 08 04:16:37.861: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 04:00:37.780: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 03:44:37.708: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 03:28:37.623: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 03:12:37.550: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 02:56:37.482: #CLI-3-LOGIN_FAILED: cliutil.c:653 Login failed. User:nouser, Service type:-8. excessive failed login attempts.
*emWeb: Mar 08 02:56:37.482: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 02:40:37.396: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 02:24:37.308: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 02:08:37.191: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 01:52:37.103: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 01:36:37.022: #CLI-3-LOGIN_FAILED: cliutil.c:653 Login failed. User:nouser, Service type:-8. excessive failed login attempts.
*emWeb: Mar 08 01:36:37.022: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 01:20:36.951: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 01:04:36.853: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 08 00:48:35.253: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 char
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
You have radius setup for
You have radius setup for managment?  If you have radius setup, make sure you don't have the managmeent check box enabled unless you are using TACACS or Radius for management users.  Seem's like radius if sending a reject back to the WLC.
-Scott
-Scott
no radius , no TACACS.only
only local authentication.
200
