WISM2 seeing its own MAC with Duplicate IP on MGMT interface
So I am just setting up a new WISM2 controller for a client.  Got it up and running and the first thing I see in the "Most Recent Traps" is this error
Warning: Controller has detected its IP Address 10.254.1.10 being used by a machine with MAC Address 30:e4:db:39:30:af.  This MAC address is itself.
I checked the settings on the 6509 which is running 15.0.1 IOS, I see that the Port-Channel 413 that it created is Down with none of the tengig interfaces assigned.
21     Po21(SU)         -        Gi1/46(P)      Gi2/10(P)
413    Po413(SD)        -
Also doing a show wism module # controller 1 status the port channel has a 0
Port Channel Number                  : 0
WCP Keep Alive Missed                : 0
Now the TenG interfaces 7/1 and 7/2 show up/up and I can obviously reach the controller through both CLI and GUI.  If anyone has an anwser for this it would be appreciated.
Everyone's tags (3)
did you configure the WiSM commands on the switch side?
Additionally, make sure that you allow VLANs that are configured in             the Cisco WiSM2 through the port-channel and Gigabit interfaces with these             commands. Make sure the VLANs are also active.
Cat-6K(config)# wism module {#} controller {#} allowed-vlan {vlan range}
Cat-6K(config)# wism module {#} controller {#} native-vlan {vlan id}
Cat-6K(config)# wism module {#} controller {#}  qos {trust/vlan-based}
 - Trust state of theLAG Interface
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Hi Stephen,
Yes I had the commands for the WISM configured but I actually have figured it out. I had to completely remove the WISM commands from the Core and reapply the same commands.  Not sure the true reasoning for having to reapply those commands but I am thinking it didnt build the Etherchannel for the 20G connection correctly the first time.
257
