11-29-2011 04:46 PM - edited 07-03-2021 09:08 PM
The client has 100 small remote offices and each office requires a wireless AP. The goal is to deploy cisco WLC 5508 at the HQ site and each site AP will connect to HQ site over the MPLS network. The client was interested to
Keep the cost low for the AP so maybe 1140 or1040 will be ok.
Question:
From design perspective , do any recommend HREAP configuration for small site AP? Any concerns with 1140
Or 1040 AP?
Any other caveats or issue I should be worry about?
Solved! Go to Solution.
11-29-2011 05:56 PM
My opinion is this:
1. If you need a WLC dedicated to do H-REAP then Flex 7500 is your first choice. Otherwise 5508 will do;
2. If you need a WLC that will do both H-REAP and standard then 5508.
11-29-2011 04:53 PM
H-REAP would be recommended.
If the entire WLC 5508 is for H-REAP purposes, then why not the Flex 7500 instead?
11-29-2011 05:38 PM
What are the major advantages over 5500? Does HREAP works better with flex 7500?
11-29-2011 05:39 PM
Flex 7500 will do nothing but HREAP. This means that your 5508 can do something else.
11-29-2011 05:46 PM
One last question: the client does have budget to care for both 7500 and 5500. I have to select either or, maybe 7500 o support HREAP for All 100 sites. Are you saying can't act as a typical WLC for HQ site?
11-29-2011 05:56 PM
My opinion is this:
11-29-2011 06:05 PM
11-30-2011 05:46 AM
saw 7500 management interface require 10gb interfaces. The customer will not invest in 10 gb LAN switches. Can I use 1 gig port for management? Or 10 gig is a hard requirement?
11-30-2011 05:58 AM
Unfortunately and mysteriously, it's a requirement to have a 10gig for the 7500. It's not Gigabit compatible ...
11-30-2011 06:52 AM
