Community Member
WLAN between LAP1140 and AP1130 (WGB-Mode) unstable
Hi Forum!
we got a WLAN with a WLC5508 (sw.-ver. 7.0.98.0) and a few AP1140. To connect a non-WLAN device to our WLAN we configured an AP1130 (sw.-ver. 12.4(10b)JDA3 to be a workgroup-bridge within our WLAN and attached the non-WLAN device to it's ethernet interface. The connection works in general - we are able to ping the AP1130 and the non-WLAN device behind this WGB-AP.
As soon as we put some load on the WLAN connection - in this case we ping the attached non-WLAN device on fas0, having the load of the term mon vty output on the WLAN connection - the WLAN connection breaks down and the AP associates to a neighboring LWAPP and back and forth.
Sometimes it reassociates 5 or 6 times.
AP1130#ping 10.32.7.34 repeat 10000
Sending 10000, 100-byte ICMP Echos to 10.32.7.34, timeout is 2 seconds:
<--- snip - lines omitted for readability --->
Oct  4 19:28:47.078: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio0, parent lost: Too many retries
Oct  4 19:28:47.083: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
Oct  4 19:28:47.170: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP AP-VW-05 18ef.639b.ab44 [None WPAv2 PSK]!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oct  4 19:28:47.170: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oct  4 19:28:52.390: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio0, parent lost: Too many retries
Oct  4 19:28:52.394: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
Oct  4 19:28:52.492: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associated To AP AP-VW-04 18ef.639b.3444 [None WPAv2 PSK]!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Oct  4 19:28:52.492: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Success rate is 100 percent (10000/10000), round-trip min/avg/max = 1/1/4 ms
At the same time the WLC-Log reports:
*apfProbeThread: Oct 04 19:28:58.973: %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: apf_80211.c:7138 Could not Process 802.11 MAC mgmt Data. Invalid toDs/fromDs bit set - packet ignored.
*iappSocketTask: Oct 04 19:28:56.033: %SOCKET_TASK-6-DATA_PROCESSING_FAILED: socket_task.c:171 Failed to process 128 bytes on protocol socket 7
*apfProbeThread: Oct 04 19:28:55.952: %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: apf_80211.c:7138 Could not Process 802.11 MAC mgmt Data. Invalid toDs/fromDs bit set - packet ignored.
*apfProbeThread: Oct 04 19:28:54.602: %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: apf_80211.c:7138 Could not Process 802.11 MAC mgmt Data. Invalid toDs/fromDs bit set - packet ignored. [...It occurred 3 times/sec!.]
*apfProbeThread: Oct 04 19:28:51.424: %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: apf_80211.c:7138 Could not Process 802.11 MAC mgmt Data. Invalid toDs/fromDs bit set - packet ignored.
*apfProbeThread: Oct 04 19:28:49.911: %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: apf_80211.c:7138 Could not Process 802.11 MAC mgmt Data. Invalid toDs/fromDs bit set - packet ignored.
*apfProbeThread: Oct 04 19:28:47.207: %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: apf_80211.c:7138 Could not Process 802.11 MAC mgmt Data. Invalid toDs/fromDs bit set - packet ignored. [...It occurred 4 times/sec!.]
*apfProbeThread: Oct 04 19:28:43.721: %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: apf_80211.c:7138 Could not Process 802.11 MAC mgmt Data. Invalid toDs/fromDs bit set - packet ignored. [...It occurred 2 times/sec!.]
The radio configuration on the WGB is:
AP1130#sh run int d0
Building configuration...
Current configuration : 234 bytes
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid xxwlan-ssid-removedxx
no mbssid
station-role workgroup-bridge
bridge-group 1
bridge-group 1 spanning-disabled
end
WLAN-Associations gives us:
AP1130#sh dot11 assoc all
Address           : 18ef.639b.3444     Name             : AP-VW-04
IP Address        : 10.34.12.7         Interface        : Dot11Radio 0
Device            : WGB-client         Software Version : NONE
CCX Version       : 5                  Client MFP       : On
State             : Assoc              Parent           : Our Parent
SSID              : xxwlan-ssid-removedxx
VLAN              : 0
Hops to Infra     : 0                  Association Id   : 1
Tunnel Address    : 0.0.0.0
Key Mgmt type     : WPAv2 PS           Encryption       : AES-CCMP
Current Rate      : 54.0               Capability       : WMM ShortHdr ShortSlot
Supported Rates   : 1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Voice Rates       : disabled
Signal Strength   : -55  dBm           Connected for    : 498 seconds
Signal to Noise   : 32  dB            Activity Timeout : 15 seconds
Power-save        : Off                Last Activity    : 0 seconds ago
Apsd DE AC(s)     : NONE
Packets Input     : 6366               Packets Output   : 2382
Bytes Input       : 1381098            Bytes Output     : 309395
Duplicates Rcvd   : 0                  Data Retries     : 110
Decrypt Failed    : 0                  RTS Retries      : 9
MIC Failed        : 0                  MIC Missing      : 0
Packets Redirected: 0                  Redirect Filtered: 0
I already:
- changed the station-role to station-role workgroup-bridge universal (using the non-WLAN devices MAC)
- enabled infrastructure-client in interface-configuration mode
- disabled the aironet-extensions (no dot11 extension aironet)
- changed the rates/speed
But nothing helped. Can anybody give me a hint what needs to be done to get more stability into this connection?
Or can anybody explain what this message means?
Any help is greatly appreciated.
Regards, Daniel
Community Member
Re: WLAN between LAP1140 and AP1130 (WGB-Mode) unstable
Have you tried different IOS versions? I would try GD versions JA3 or JDA3 if you aren't already running one of those two.
Community Member
Hi Elliot,
yes, i tried different versions, but without any effect. I changed the radio, today. I have been using the 2,4GHz radio on the WGB, before. Now, using the 5GHz radio the connection seems to be stable, even under load. Our Cisco support partner recommended to add the command "no mobile station" to the radio config.
He said this would deactivate the background channel scanning and should add stability to the wlan connection. But i haven't tried that, yet.
The WLC keeps posting the mentioned message, serveral times per second.
Regards, Daniel
Community Member
Hi Daniel,
are you still getting the same issue?
Im getting the same message "%APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED" and Im using the same sw version.
Were you able to found out something regarding this issue?
Best regards,
Norberto
Community Member
Hi Norberto,
no, i haven't found any informations regarding that message, yet. But i forwarded all informations to our Cisco support partner, today. And i hope they can provide informations regarding that message. Our WLC posts multiple messages every second.
Do you use a similar setup? WLC and LWAPPs with APs in WGB-Mode attached?
Regards, Daniel
Community Member
Running a WLC4402 (SW 7.0.98.0) with 35 x LAP1252 APs and I am still seeing this message every few seconds as well.  So far I haven't been able to determine the cause or resolution for this message.
Community Member
Has this been resolved?  I'm getting a ton of these "errors" in my syslog.  The only thing I could find on Cisco's site was a reference stating that it would be fixed in later releases.  I'm using 7.0.98.205 on a 4402.
Apr 01 15:23:03.602:  %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: Could not Process 802.11 MAC mgmt Data.  Invalid toDs/fromDs bit set - packet ignored.
Apr 01 15:23:05.048:  %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: Could not Process 802.11 MAC mgmt Data.  Invalid toDs/fromDs bit set - packet ignored.
Apr 01 15:23:07.454:  %APF-6-PROC_DOT11_MAC_MGMT_DATA_FAILED: Could not Process 802.11 MAC mgmt Data.  Invalid toDs/fromDs bit set - packet ignored. [...It occurred 2  times/sec!.]
Community Member
No, this has not been resolved, yet.
Regards, Daniel
Silver
Hmmm.. TAC would say that it is not supported due to different platforms in use.
However... I would recommend you using same units on both sides with same IOS version.
Even running same units but with different IOS version is not recommended and not supported. Unexpected behaviors could appear.
just my 2 cents..
4099
