Community Member
WLAN Guest access on Branch offices - REAP?
Hi Everybody
We would like to deploy a WLAN Solution based on WLC 4400 (4402) and 1030 AP in the branch office (and 1010 AP in the central office).
The thing is:
We would like to send all Guest-WLAN access through the LWAPP tunnel (AP's in Local mode) to the central Firewall (separate VLAN) and the Corporate-WLAN access locally out on every Branch (untill now using REAP).
Unfortenately we have not found out how to select the "AP mode" - local / REAP defined per SSID.
Does anyone have an idea? Did anyone already solve this design issue?
A solution would probably be to create separate VLAN's on each branchoffice, using VRF and GRE tunneling to the Central site- but this requires a lot of configuring (and network re-design)..
Best Regards
Jarle
Silver
Re: WLAN Guest access on Branch offices - REAP?
The solution which you have suggested will do
Community Member
Have you seen some config examples of using VRF and GRE? I've just started digging and am coming up dry.
172
