Community Member
wlan on ssid i need help
hello I have a question .
I have two ssid but i must subnet in 30 networks, each ssid must be with 15 vlan like minimum...
the case is that I have but of 30 sites with two subnetworks wifi.....
thank you....
1 ACCEPTED SOLUTION
Silver
Re: wlan on ssid i need help
Each SSID can be mapped to only one VLAN, so if you want to have 15 WLANs you should have 15 SSIDs. Which wireless solution are you using? Autonomous or Centralized solution?
Silver
Community Member
ok thank you for help, but the situation was solved.
we are using wlc4404
138
