05-24-2007 02:15 PM - edited 07-03-2021 02:07 PM
Does the 2006 WLC support LAG (i.e., logically connecting its 4 100 Mb/s ethernet ports together like EtherChannel)?
Solved! Go to Solution.
05-24-2007 09:27 PM
Hi Friend,
Unfortunately this feature is not available on 2006 controller.
Only 4404, 4402 supports lag.
Ankur
*Pls rate all helpfull post
05-24-2007 09:27 PM
Hi Friend,
Ankur
