Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
wlc 2106 overheating
is normal temperature of WLC2106 between 58 and 65?C? Controller crases time to time. It must be hard reseted. Environment temperature is constantly 20?C.
Re: wlc 2106 overheating
Make sure that you have plenty of ventilation around the unit. If it is sitting on top of switch or another controller, it WILL get hot. You may need to raise it up a few inches or put it on a shelf of it own to get a little more air flow around it.
Good luck
It have enough free place around. So that is not a problem.
211
