WLC 2125 with 2x 1520 Mesh Points - Ethernet Bridging
Hi - I'm looking for assistance with a new Mesh set up we are deploying, the solutions consists of:
1x Wireless LAN Controller 2125
2x 1520 AP/Mesh Points
What we are trying to achieve is to bridge two networks together, I have followed the Cisco configuration guide and I simply can't get the traffic to cross from one side to the other. The WLC can see both 1520's on either side of the mesh network and I appear to have set it up right.
Here is how everything is set up:
- Local network (Class B, 10.0.0.0/16) connected to Port 1 on the WLC.
- 1520 is connected to Port 2 on the WLC via g0/0 with an IP address of 10.0.3.110 (management network, 10.0.3.111 for the wlan-management network) - this is set up as the RootAP, with ethernet bridging enabled and the bridging group set to rsqmesh.
- 2nd 1520 is around 800ft away set up as a MeshAP with ethernet bridging enabled and the bridging group set to rsqmesh. Small 5-port switch (non-cisco) connect to g0/0 on this 1520 with a device attached which has the IP of 10.0.3.37.
All help is appreciated.
Craig.
1 ACCEPTED SOLUTION
Gold
Re: WLC 2125 with 2x 1520 Mesh Points - Ethernet Bridging
Bridging will not work if the RAP is directly connected to the controller. But CSCsk15792 is filed on this issue. If you put a switch between the controller and RAP traffic should start flowing.
1 REPLY
Gold
182
