11-05-2013 10:32 PM - edited 07-04-2021 01:13 AM
I am facing the following issue with my 2504 after doing my 7.5 Code upgrade .. Not sure what triggered it. ANyone knows the solution?
11-06-2013 12:46 AM
I feel its like a memory problem....
show boot (to see images that are sitting on the wlc)
show memory statistics (to see the memory)
Can you paste the full console logs ??
As per my knowledge you must create a case with TAC.
11-06-2013 04:32 AM
Please post the error. If the error occurs during the boot and the WLC fails to fully boot up and you don't get a prompt, then most likely your image is corrupt or your unit just failed. Either way, you will need to open a TAC case to either get a recovery image and the direction to upload that to the WLC or else you will have to RMA the unit. You would need a support contract to open a TAC case though.
If your WLC does boot up okay and you get a prompt, then your in a better spot:). Just post the error.
