01-23-2014 02:43 AM - edited 07-05-2021 12:02 AM
since a few days I cannot access the web interface anymore via wired lan. I can ping the management interface, but all other communication via wired lan fails: no web interface, no authentication anymore to radius server, cannot upload configs or logs anymore.
Settings haven't changed for a few years, I already have done a soft reset.
Does anyone have a suggestion ?
Solved! Go to Solution.
01-23-2014 03:25 AM
There were some bugs with regards to that (older code), but when you said you soft reset, I thought you rebooted the WLC.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
01-23-2014 02:54 AM
You still have console and able to telnet or ssh?
01-23-2014 02:59 AM
I can connect to the console (via console cable), Guest users can still connect wirelessly (static key), but ssh does not work (although it is allowed in the configuration). Telnet is not allowed.
Basically I can only ping via the wire.
01-23-2014 02:59 AM
Here is what I would do... Perform a constant ping to the WLC management IP and then reboot the WLC or unplug the WLC from the network. Make sure the ping stops!!! At least we know there isn't a duplicate IP address.
01-23-2014 03:18 AM
It is not a case of duplicate ip's: at reset of the system the pings stopped, and started again when system was up again.
However after this reset, i can connect again to web interface via wired link, for now at least.
01-23-2014 03:25 AM
Scott
01-23-2014 04:45 AM
I did indeed a "reset system" this morning, just like I did this afternoon. However this morning it didn't solve the issue, and now it did.
Anyway, thanks a lot for a VERY FAST response. This is quite reassuring.
Koen
01-23-2014 04:48 AM
No problem. I would just monitor that because that would get annoying if it started happening more often.
