WLC 4402-12-K9 upgrade to 25 access points
peter_lengyel
Hi everyone,
my customer has an AIR-WLC4402-12-K9 using 12 access point with it, and they would like to increase the number of APs in use. Is there an upgrade option for 25? I couldn't find anything, but I suppose the hardware is the same, it's the software that differs.
If not, can they buy another AIR-WLC4402-12-K9 and connect it to the existing one? Can the software handle to controllers in the same wireless system?
Thanks in advane for all the input!
Peter
andrew.prince
Level 10
Level 10
Peter,
Sadly the 44xx units are based on AP management - not a software. You could have another AIR-WLC4402-12-K9 and place the secondary in the same mobility group for seemless wireless networking....however if a WLC fails - you have lost the extra 12 AP capacity!
It would probably make sense to by a AIR-WLC4402-25-K9 or even a AIR-WLC4402-50-K9 for future expansion!
HTH.
andrew.prince
Level 10
Level 10
Peter,
HTH.
Hi Andrew,
thanks for the quick reply!
NP - glad to help.
How to upgrade the AIR-WLC4402-12-K9  to support more number of APs .
Could any one share the part code for the licnese.
Thanks & Regards
Lakshman Kumar S
