Community Member
WLC 4402-12-K9 upgrade to 25 access points
Hi everyone,
my customer has an AIR-WLC4402-12-K9 using 12 access point with it, and they would like to increase the number of APs in use. Is there an upgrade option for 25? I couldn't find anything, but I suppose the hardware is the same, it's the software that differs.
If not, can they buy another AIR-WLC4402-12-K9 and connect it to the existing one? Can the software handle to controllers in the same wireless system?
Thanks in advane for all the input!
Peter
1 ACCEPTED SOLUTION
Re: WLC 4402-12-K9 upgrade to 25 access points
Peter,
Sadly the 44xx units are based on AP management - not a software. You could have another AIR-WLC4402-12-K9 and place the secondary in the same mobility group for seemless wireless networking....however if a WLC fails - you have lost the extra 12 AP capacity!
It would probably make sense to by a AIR-WLC4402-25-K9 or even a AIR-WLC4402-50-K9 for future expansion!
HTH.
Peter,
HTH.
Community Member
Hi Andrew,
thanks for the quick reply!
NP - glad to help.
Community Member
How to upgrade the AIR-WLC4402-12-K9  to support more number of APs .
Could any one share the part code for the licnese.
Thanks & Regards
Lakshman Kumar S
1454
