WLC-4402 Distribution port link down
I have a problem with WLC-4402. After basic configuration I can login to web gui of the controller, but I can't get the distribution ports to be up. The link is still down. I'm not sure if SFP modules Signamax 1000BASE-T are compatible with the controller. In web gui Controller - Inventory Gig Ethernet/Fiber Card there is Absent! Does it mean that they're not compatible? Controller's SW: 6.0.196.0 Thanks a lot.
1 ACCEPTED SOLUTION
Hello Jan,
Please mark the Question as Answered, if the provided information by VIP Leo is correct and it helped. By doing that others can take benefit as well.
Vinay Sharma
Community Manager – Wireless
Thanks & Regards
Hall of Fame Super Gold
Re: WLC-4402 Distribution port link down
If it ain't got "Cisco" logo then it won't be compatible.
Problem solved, after connection to 1Gbit switch everything works well. Thanks a lot.
Hello Jan,
Vinay Sharma
Thanks & Regards
566
