How do you have the trunk ports and port channel setup?
On the switch run:
show etherchannel load-balance
Make sure it is set to src-dst-ip, if not then.
port-channel load-balance src-dst-ip
You Port Channel should look like this:
interface Port-channel2
description WLC
switchport
switchport access vlan 10
switchport trunk native vlan 10
switchport trunk allowed vlan 12,10,25
switchport mode trunk
Your trunk should look like this
interface GigabitEthernet1/45
description WLC
switchport
no cdp enable
channel-group 3 mode on
spanning-tree portfast
-Scott
