10-22-2008 01:30 AM - edited 07-03-2021 04:39 PM
I'm trying to setup a WLC526 with two WLANs, one for the internal network and one for guest access.
I have the internal corporate network WLAN configured with RADIUS and all worked fine.
All users get IP addresses from the DHCP server and can access network resources.
For this internal network i used PORT1 of the WLC.
After that i plug a router (lan connection with configured dhcp server - linksys) into the PORT1 of the WLC with a different IP Range.
I can create the GUEST WLAN and SSIDs with Guest Users. Machines can connect to the WLAN, but they get no IP from DHCP Linksys and no internet access.
And it is not possible to ping the linksys router from the WLC 526 console.
Where is the Mind bug?
10-23-2008 01:28 PM
Hi there!
I'm just trying to make my first steps with the wlc526. Which radius-server did you use?
Thank you!
10-24-2008 06:15 AM
VLANS configured?
10-26-2008 08:03 AM
Well. You say you plugged the linksys directly into port 1. To do that you had to unplug your working network. You need to use a layer 3 switch, vlans configured and trunked for each network. Make sure you have the management interface and any dynamic interfaces for the SSIDs configured with appropriate addresses for each interface (interface, gateway, and dhcp scope for each network) in place. If you still can not get an address from the linksys then you will need to turn off the dhcp proxy on the controller. From the cli it is "config dhcp proxy disable" I think. This will allow client to go straight to the linksys for dhcp and not use the virtual interface for proxy. If this doesn't make sense look at the configuration guide for a 2106 as the code is basically the same for the 526 and much better documented.
10-27-2008 02:29 AM
10-27-2008 01:45 AM
I use the Windows IAS
10-27-2008 01:16 PM
I don't think your linksys is going to do what you want it to do my friend.
11-10-2008 02:52 AM
Please push me in the right direction! Thanks
