WLC 5500 with NPS DHCP not working
Hi.. I had a NPS issue earlier and was able to get that squared away.. it gets associated to the WLAN and also authenticated with NPS..
but when it trys and grab a DHCP or IP address it never gets it...  here is the debug client I ran on the WLC...
btw I setup a Guest Wlan which is on a different subnet say ex. 231.8 and it worked without any issues but that authenticated using PSK and web policy.
it pulls the DHCP address from the correct scope which is my external DHCP server.
the other  WLAN I setup with AD credentials is the one I am having issue with and the subnet for ex. is 232.8 ,
172.17.16.50 = my external DHCP server
172.17.232.8 = my WLAN interface
172.17.232.1 = route address I setup in my dhcp scope options
please see thru the log and see if anything comes to mind.. and also ask me any questions if you need to know my setup.
ip helper  was setup on that subnet, it did not do anything.
Thanks.
type = Airespace AP Client
  on AP 24:01:c7:ed:48:70, slot 0, interface = 13, QOS = 0
  IPv4 ACL ID = 255, IPv6 ACL ID = 25
*apfReceiveTask: Sep 19 16:44:08.980: 00:14:a5:4b:cf:ef  0.0.0.0 RUN (20) Fast Path rule (contd...) 802.1P = 0, DSCP = 0,  TokenID = 15206  Local Bridging Vlan = 232, Local Bridging intf id = 13
*apfReceiveTask: Sep 19 16:44:08.982: 00:14:a5:4b:cf:ef 0.0.0.0 RUN (20) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*pemReceiveTask: Sep 19 16:44:08.982: 00:14:a5:4b:cf:ef 0.0.0.0 Added NPU entry of type 9, dtlFlags 0x0
*pemReceiveTask: Sep 19 16:44:08.982: 00:14:a5:4b:cf:ef Sent an XID frame
*pemReceiveTask: Sep 19 16:44:08.983: 00:14:a5:4b:cf:ef 0.0.0.0 Added NPU entry of type 1, dtlFlags 0x0
*pemReceiveTask: Sep 19 16:44:08.983: 00:14:a5:4b:cf:ef Pushing IPv6: fe80:0000:0000:0000: 290f:8f76:9221:b33d , and MAC: 00:14:A5:4B:CF:EF , Binding to Data Plane. SUCCESS !!
*pemReceiveTask: Sep 19 16:44:08.983: 00:14:a5:4b:cf:ef 0.0.0.0, VLAN Id 232 Not sending gratuitous ARP
*apfOrphanSocketTask: Sep 19 16:44:09.203: 00:14:a5:4b:cf:ef Orphan Packet from STA - IP 169.254.179.61
*apfOrphanSocketTask: Sep 19 16:44:09.203: 00:14:a5:4b:cf:ef  In apfRegisterIpAddrOnMscb_debug: regType=2  Invalid src IP address,  169.254.179.61 is part of reserved ip address range (caller  apf_broff.c:229)
*apfOrphanSocketTask: Sep 19 16:44:09.203: 00:14:a5:4b:cf:ef IPv4 Addr: 169:254:179:61
*DHCP Socket Task: Sep 19 16:44:10.760: 00:14:a5:4b:cf:ef DHCP received op BOOTREQUEST (1) (len 308,vlan 230, port 13, encap 0xec03)
*DHCP Socket Task: Sep 19 16:44:10.760: 00:14:a5:4b:cf:ef DHCP selecting relay 1 - control block settings:
                                                dhcpServer: 0.0.0.0, dhcpNetmask: 0.0.0.0,
                                                dhcpGateway: 0.0.0.0, dhcpRelay: 0.0.0.0  VLAN: 0
*DHCP Socket Task: Sep 19 16:44:10.760: 00:14:a5:4b:cf:ef DHCP selected relay 1 - 172.17.16.50 (local address 172.17.232.8, gateway 172.17.232.1, VLAN 232, port 13)
*DHCP Socket Task: Sep 19 16:44:10.760: 00:14:a5:4b:cf:ef DHCP selecting relay 2 - control block settings:
                                                dhcpGateway: 0.0.0.0, dhcpRelay: 172.17.232.8  VLAN: 232
*DHCP Socket Task: Sep 19 16:44:10.760: 00:14:a5:4b:cf:ef DHCP selected relay 2 - 172.16.16.50 (local address 172.17.232.8, gateway 172.17.232.1, VLAN 232, port 13)
*DHCP Socket Task: Sep 19 16:44:10.761: 00:14:a5:4b:cf:ef DHCP selecting relay 1 - control block settings:
*DHCP Socket Task: Sep 19 16:44:10.761: 00:14:a5:4b:cf:ef DHCP selected relay 1 - 172.17.16.50 (local address 172.17.232.8, gateway 172.17.232.1, VLAN 232, port 13)
*DHCP Socket Task: Sep 19 16:44:10.761: 00:14:a5:4b:cf:ef DHCP transmitting DHCP DISCOVER (1)
*DHCP Socket Task: Sep 19 16:44:10.761: 00:14:a5:4b:cf:ef DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Sep 19 16:44:10.761: 00:14:a5:4b:cf:ef DHCP   xid: 0x28db99ea (685480426), secs: 1280, flags: 0
*DHCP Socket Task: Sep 19 16:44:10.761: 00:14:a5:4b:cf:ef DHCP   chaddr: 00:14:a5:4b:cf:ef
*DHCP Socket Task: Sep 19 16:44:10.761: 00:14:a5:4b:cf:ef DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Sep 19 16:44:10.761: 00:14:a5:4b:cf:ef DHCP   siaddr: 0.0.0.0,  giaddr: 172.17.232.8
*DHCP Socket Task: Sep 19 16:44:10.761: 00:14:a5:4b:cf:ef DHCP ARPing for 172.17.232.1 (SPA 172.17.232.8, vlanId 232)
*DHCP Socket Task: Sep 19 16:44:10.761: 00:14:a5:4b:cf:ef DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Sep 19 16:44:10.761: 00:14:a5:4b:cf:ef DHCP selected relay 2 - 172.16.16.50 (local address 172.17.232.8, gateway 172.17.232.1, VLAN 232, port 13)
*DHCP Socket Task: Sep 19 16:44:10.761: 00:14:a5:4b:cf:ef DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 2
*DHCP Socket Task: Sep 19 16:44:17.837: 00:14:a5:4b:cf:ef DHCP received op BOOTREQUEST (1) (len 308,vlan 230, port 13, encap 0xec03)
*DHCP Socket Task: Sep 19 16:44:17.837: 00:14:a5:4b:cf:ef DHCP selecting relay 1 - control block settings:
*DHCP Socket Task: Sep 19 16:44:17.837: 00:14:a5:4b:cf:ef DHCP selected relay 1 - 172.17.16.50 (local address 172.17.232.8, gateway 172.17.232.1, VLAN 232, port 13)
*DHCP Socket Task: Sep 19 16:44:17.837: 00:14:a5:4b:cf:ef DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Sep 19 16:44:17.837: 00:14:a5:4b:cf:ef DHCP selected relay 2 - 172.16.16.50 (local address 172.17.232.8, gateway 172.17.232.1, VLAN 232, port 13)
*DHCP Socket Task: Sep 19 16:44:17.838: 00:14:a5:4b:cf:ef DHCP transmitting DHCP DISCOVER (1)
*DHCP Socket Task: Sep 19 16:44:17.838: 00:14:a5:4b:cf:ef DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Sep 19 16:44:17.838: 00:14:a5:4b:cf:ef DHCP   xid: 0x28db99ea (685480426), secs: 3072, flags: 0
*DHCP Socket Task: Sep 19 16:44:17.838: 00:14:a5:4b:cf:ef DHCP   chaddr: 00:14:a5:4b:cf:ef
*DHCP Socket Task: Sep 19 16:44:17.838: 00:14:a5:4b:cf:ef DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Sep 19 16:44:17.838: 00:14:a5:4b:cf:ef DHCP   siaddr: 0.0.0.0,  giaddr: 172.17.232.8
*DHCP Socket Task: Sep 19 16:44:17.838: 00:14:a5:4b:cf:ef DHCP sending REQUEST to 172.17.232.1 (len 350, port 13, vlan 232)
*DHCP Socket Task: Sep 19 16:44:17.838: 00:14:a5:4b:cf:ef DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Sep 19 16:44:17.838: 00:14:a5:4b:cf:ef DHCP selected relay 2 - 172.16.16.50 (local address 172.17.232.8, gateway 172.17.232.1, VLAN 232, port 13)
*DHCP Socket Task: Sep 19 16:44:17.838: 00:14:a5:4b:cf:ef DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 2
*DHCP Socket Task: Sep 19 16:44:34.478: 00:14:a5:4b:cf:ef DHCP received op BOOTREQUEST (1) (len 308,vlan 230, port 13, encap 0xec03)
*DHCP Socket Task: Sep 19 16:44:34.478: 00:14:a5:4b:cf:ef DHCP selecting relay 1 - control block settings:
*DHCP Socket Task: Sep 19 16:44:34.478: 00:14:a5:4b:cf:ef DHCP selected relay 1 - 172.17.16.50 (local address 172.17.232.8, gateway 172.17.232.1, VLAN 232, port 13)
*DHCP Socket Task: Sep 19 16:44:34.478: 00:14:a5:4b:cf:ef DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Sep 19 16:44:34.478: 00:14:a5:4b:cf:ef DHCP selected relay 2 - 172.16.16.50 (local address 172.17.232.8, gateway 172.17.232.1, VLAN 232, port 13)
*DHCP Socket Task: Sep 19 16:44:34.479: 00:14:a5:4b:cf:ef DHCP selected relay 1 - 172.17.16.50 (local address 172.17.232.8, gateway 172.17.232.1, VLAN 232, port 13)
*DHCP Socket Task: Sep 19 16:44:34.479: 00:14:a5:4b:cf:ef DHCP transmitting DHCP DISCOVER (1)
*DHCP Socket Task: Sep 19 16:44:34.479: 00:14:a5:4b:cf:ef DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Sep 19 16:44:34.479: 00:14:a5:4b:cf:ef DHCP   xid: 0x28db99ea (685480426), secs: 7168, flags: 0
*DHCP Socket Task: Sep 19 16:44:34.479: 00:14:a5:4b:cf:ef DHCP   chaddr: 00:14:a5:4b:cf:ef
*DHCP Socket Task: Sep 19 16:44:34.479: 00:14:a5:4b:cf:ef DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Sep 19 16:44:34.479: 00:14:a5:4b:cf:ef DHCP   siaddr: 0.0.0.0,  giaddr: 172.17.232.8
*DHCP Socket Task: Sep 19 16:44:34.479: 00:14:a5:4b:cf:ef DHCP sending REQUEST to 172.17.232.1 (len 350, port 13, vlan 232)
*DHCP Socket Task: Sep 19 16:44:34.479: 00:14:a5:4b:cf:ef DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Sep 19 16:44:34.479: 00:14:a5:4b:cf:ef DHCP selected relay 2 - 172.16.16.50 (local address 172.17.232.8, gateway 172.17.232.1, VLAN 232, port 13)
*DHCP Socket Task: Sep 19 16:44:34.479: 00:14:a5:4b:cf:ef DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 2
*DHCP Socket Task: Sep 19 16:44:34.479: 00:14:a5:4b:cf:ef Failed to get response for 3 dhcp attempts from client.Total DHCP failed count for the interface aginternet : 1
*apfMsConnTask_7: Sep 19 16:44:48.419: Stats update: Non Zero value
*DHCP Socket Task: Sep 19 16:45:05.433: 00:14:a5:4b:cf:ef DHCP received op BOOTREQUEST (1) (len 308,vlan 230, port 13, encap 0xec03)
*DHCP Socket Task: Sep 19 16:45:05.433: 00:14:a5:4b:cf:ef DHCP selecting relay 1 - control block settings:
*DHCP Socket Task: Sep 19 16:45:05.433: 00:14:a5:4b:cf:ef DHCP selected relay 1 - 172.17.16.50 (local address 172.17.232.8, gateway 172.17.232.1, VLAN 232, port 13)
*DHCP Socket Task: Sep 19 16:45:05.433: 00:14:a5:4b:cf:ef DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Sep 19 16:45:05.434: 00:14:a5:4b:cf:ef DHCP selected relay 2 - 172.16.16.50 (local address 172.17.232.8, gateway 172.17.232.1, VLAN 232, port 13)
*DHCP Socket Task: Sep 19 16:45:05.434: 00:14:a5:4b:cf:ef DHCP selecting relay 1 - control block settings:
*DHCP Socket Task: Sep 19 16:45:05.434: 00:14:a5:4b:cf:ef DHCP selected relay 1 - 172.17.16.50 (local address 172.17.232.8, gateway 172.17.232.1, VLAN 232, port 13)
*DHCP Socket Task: Sep 19 16:45:05.434: 00:14:a5:4b:cf:ef DHCP transmitting DHCP DISCOVER (1)
*DHCP Socket Task: Sep 19 16:45:05.434: 00:14:a5:4b:cf:ef DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*DHCP Socket Task: Sep 19 16:45:05.434: 00:14:a5:4b:cf:ef DHCP   xid: 0xeabd8433 (3938288691), secs: 0, flags: 8000
*DHCP Socket Task: Sep 19 16:45:05.434: 00:14:a5:4b:cf:ef DHCP   chaddr: 00:14:a5:4b:cf:ef
*DHCP Socket Task: Sep 19 16:45:05.434: 00:14:a5:4b:cf:ef DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*DHCP Socket Task: Sep 19 16:45:05.434: 00:14:a5:4b:cf:ef DHCP   siaddr: 0.0.0.0,  giaddr: 172.17.232.8
*DHCP Socket Task: Sep 19 16:45:05.434: 00:14:a5:4b:cf:ef DHCP sending REQUEST to 172.17.232.1 (len 350, port 13, vlan 232)
*DHCP Socket Task: Sep 19 16:45:05.434: 00:14:a5:4b:cf:ef DHCP selecting relay 2 - control block settings:
*DHCP Socket Task: Sep 19 16:45:05.434: 00:14:a5:4b:cf:ef DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 2
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: WLC 5500 with NPS DHCP not working
Have you tried connecting a laptop to a switchport configured for that vlan to test?
-Scott
BUMP.... Can anyone help me with this problem ?
THanks.
-Scott
Thanks for the replay and good troubleshooting step.. I Just tried.. it looks like my laptop is not getting any DHCP when I connect my laptop to that switchport on that Vlan..
will need to speak to my data communications team and see why it isnt working..
I checked the port it look like it has the right Vlan on it..
will report back..
anything else I should have them look into ?
No... they are probably not extending that vlan throught the trunk port... once your laptop gets an ip, then you should be good.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Scott  thank you for your help.. I was able to have our data communications team fix the problem.. apprently  DHCP was blocked in the ACL.. they allowed it and  my clients are connected and getting DHCP now..
Sounds good. Can you mark the question answered as it helps when others run into a similar issue.
-Scott
Hey Scott.
how do I mark the question as answered ?  I cant see to find that option.
You should have an option where you rate the post.
Scott
-Scott
493
