03-26-2014 05:18 AM - edited 07-05-2021 12:32 AM
We have 5508 WLC and adding a new 5760..
is it possible for this 2 to be in the N+1 model?
If the 5508 WLC goest down, does the AP previously associated to 5508 need to re-download the image to join 5760?
Or as long as it's running within the following compatibility matrix, The AP wouldn't need to re-download?
Thanks for all the answers
Solved! Go to Solution.
03-26-2014 11:48 AM
No, AP will always download the image when they move between 5760 & 5508. Even though they are compatible, AP image is not same in those two platform (Cisco will make this happen in future, but not today).
So it is not a good idea to keep 5760 & 5508 in N+1 setup. Always go with similar platform & firmware versions.
Rasika
*** Pls rate all useful responses ***
03-26-2014 11:48 AM
Rasika
03-26-2014 11:08 PM
ah i see..
but it wouldn't be a problem for them to be in the same mobility domain right?
user should be able to roam between the two?
thanks for the answer
03-26-2014 11:36 PM
Yes, you can put them in same mobility group.
To do this you have to enable "New Mobility" feature of your 5508 & configure the mobility between each others.
Since 7.5.x is deffered only 7.6.x is the option for this. (7.4.x is not supporting this feature). This will enable CAPWAP inter-controller communication instead of EoIP (used by legacy controllers 5508,2504, WiSM)
Rasika
**** Pls rate all useful responses ****
03-26-2014 11:46 PM
great answer, thanks again!
