08-28-2013 04:38 AM - edited 07-04-2021 12:43 AM
I tried installing chained certificate in for the https access in wlc 5508. It failed and later i came to know it will only accept unchained cert for management access. But now the problem is i could not get GUI access. It shows error like "This server security certificate is revoked "
What should i do now..?
Solved! Go to Solution.
08-28-2013 04:47 AM
Try different browser if that works.
If not, try to generate new self signed certified for management.
login to the CLI if that is possible and issue the command:
config certificate generate webadmin
Amjad
Rating useful replies is more useful than saying "Thank you"
08-28-2013 04:47 AM
Amjad
08-28-2013 06:50 AM
Thanks for your reply. do you have any idea on how to get unchained cert for Management.?
08-28-2013 07:24 AM
you can read this doc:
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080a77592.shtml
08-28-2013 10:03 AM
Amjad,
Do you mean this link for unchained certs ?
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00806e367a.shtml
__________________________________________________________________________________________
"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
08-28-2013 10:49 PM
George,
Believe it or not but this is the first time that I notice that there are two different documents about this!!
Checking the contents of both documents you are right. One is chained certs and one for unchained certs.
The doc of the chained certs has more steps included like combining all the certs in one cert.
08-28-2013 10:55 PM
Prasan,
sorry I just noticed that you are asking about the management cert.
unfortunately the chained certs are only supported for webauth but not for the management.
08-29-2013 12:19 AM
Yeah ... That is true .. It was not supporting when i tried to put chained cert for management.
I will try to get unchained cert and upload..
08-29-2013 12:21 AM
Good luck.
08-29-2013 05:11 AM
The unchained works fine with an internal
CA and as long as you enter the WLC in DNS. Make sure you use the DNS name when accessing the WLC.
08-29-2013 11:44 PM
Thank you Scott
